Question about Kenmore Elite 45986 Front Load Washer
What detergent do u use for this type of washer
    Problem Solver:
  • 13 Answers
You have to use HE High Efficiency detergent which is a low sudsing detergent, ERA , Tide makes one, do not use regular detergent which will cause too much sudsing and will void your warrenty, you will be suprised on how little detergent is used with a front loading washing machine compared with a top loading machine
Posted on Nov 08, 2010
Samsung washer error code f1
What kind of detergent are you using? F1 in most cases means that the wrong type of detergent is being used. If it's a front-loader, you should be using h3 detergent.
May 21, 2012 | Samsung Clothes Washer Power Control Board...
My Simpson 806 Heavy duty washer fills then stops, flashes SF on screen and beeps. Anyone got a solution?
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
on certain models the "sf" stands for service filter.
Jan 12, 2012 | Washing Machines
SIMPSON 816 ENCORE WASHING MACHINE ERROR MESSAGE
Hello
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
Display shows sud
"SUD" is a Suds Detect error code. The following link explains the error and potential causes:
http://www.fixya.com/support/r3608687-sud_error
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use small amounts of water. Using the wrong type of detergent can also void any warranty you may have.
NOTE: HE detergent does not have a lot of suds, which often confuses consumers into thinking they aren't using enough detergent. With HE washers little to no suds if normal and preferred.
Secondary causes can come from something restricting the drainage system. Most notably, something lodged in the drain pump and/or drain hose(s). I've included a follow-on link that explains how to check the drain pump reservior if required.
Read through the link provided and let me know if you still have questions. I hope this helps you.
Apr 22, 2010 | Kenmore 45087 Front Load Washer
Can you use regulure detergent instead of the HD kind? The type of maytags I purchased are MEDE500VW and MHWE450WW washer
High Efficiency detergent is strongly recommended for front-load washers. This detergent is a "low sudsing" detergent as opposed to the regular detergent. If you use regular detergent is a front-load unit, you may have issues down the road!
Apr 13, 2010 | Maytag MEDE500W Dryer
The washing machine will not get past the sud code.
This is a Suds Detect error code. The following link explains the error and potential causes:
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code
The number one cause of the error is from using too much, or the wrong type of detergent. You are required to High Efficiency (HE) detergent with these washers because the concentration is formulated for HE washers that use minimal amounts of water. Using the wrong type of detergent can also void any warranty you may have.
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Heavy towels don't come clean & smell of mildew - all whites and colours are gray after bleach has been used.
Did you add detergent to the dispenser?
For best results, add detergent to the detergent
compartment. Do not add detergent to the washer drum.
 Did you sort properly?
Sort lint givers (towels, chenille) from lint takers (corduroy,
synthetics). Dye transfer can occur when mixing whites and
colors in a load. Sort dark clothes from whites and lights.
 Did you overload the washer?
Do not overload the washer. The washer can be fully loaded,
but not tightly packed. The wash load must be balanced. Lint
can be trapped in the load if overloaded.
 Check the following:
Was paper or tissue left in pockets?
 Did you use enough HE detergent?
Follow manufacturer’s recommendations for the type of load
you are washing. For best performance, use only High
Efficiency detergent. Use enough HE detergent to remove soil
and hold it in suspension.
 Do you have hard water?
Use more detergent for washing heavy soils in cold or hard
water.
 Is your water colder than 60°F (15.6°C)?
Wash water colder than 60°F (15.6°C) may not completely
dissolve the detergent. Use hot or warm washes if safe for the
fabric load. Make sure your hot water system is adequate to
provide a hot water wash.
 Have you run the Clean Washer Cycle lately?
To freshen your washer and to avoid odors, see “Cleaning
Your Washer.”
 Are you using HE detergent?
Use of non-HE detergent can cause a film residue which can
result in odor.
 Did you leave the door open after use?
This washer has a tight seal to avoid water leaks. To avoid
odors leave the door open to allow the washer to dry
between uses.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10117768.pdf
(see page 20 for washer cleaning instructions)
Oct 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Type of detergent in front-loading washers
yes make sure the box of detergent says HE on it. and read the directions on the soap box for load size and amount.
Jun 20, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Elite 45986 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
