Question about Peg Perego John Deere Gator HPX Ride on Toy
I have the gator with the electric dump bed and the cylinder has stopped working. It runs but does not raise the bed. Is there a replacement cylinder? Where can I find the part if it is available.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can check on ebay for a used one, or i can order you one, but ebay would be cheaper
Posted on Jun 13, 2012
5 Suggested Answers
  • 156 Answers
SOURCE: How does the dump bed on the gator work?
There should be a green piston with a red handle behind the seat. Some of the models come with a automatic piston assembly. Mine did not come with one, but I found it at this website http://www.shopjandl.com/ikcg0001.html
Hope this helps.
Posted on May 13, 2009
  • 156 Answers
SOURCE: We bought a used gator, how do you get the dump bed to work???
This may have been solved already but here is the info if you need it.
There should be a green piston with a red handle behind the seat. Some of the models come with a automatic piston assembly. Mine did not come with one, but I found it here
Hope this helps.
Posted on Jun 01, 2009
  • 156 Answers
SOURCE: I am trying to assemble a john deere gator and do ...
it should be on the green cylinder behind the seat, but you can contact the repair desk at http://www.mypegperegoparts.com/
and they can walk you through it. I also got my replacement parts from them.
hope this helps
Posted on Jun 08, 2010
  • 25 Answers
SOURCE: The Cargo Bed on my
none
Posted on Jun 21, 2011
Gator won't work in 2nd Gear
sounds like you have a bad motor, you'll need to pull the dump bed off to acess the motors and disconnect one and then see if it works
May 22, 2013 | Peg Perego John Deere Gator HPX Ride on...
How to replace the tires on a Deere Gator
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels and axle
4. remove the red pin at the front of the dump bed
5. remove the two black pins at the rear of the dump bed
6. remove the dump bed
7. lift the green plastic cover off
8. remove the two screws that hold the gearbox and motor to the body
9. remove the gearbox and motor assembly
10. remove the two screws that hold the motor to the gearbox
Nov 29, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to connect a disconnect motor on a john deere
1. remove the red pin at the front of the dump bed
2. remove the two black pins at the rear of the dump bed
3. remove the dump bed
4. lift the green plastic cover off
Oct 23, 2012 | Peg Perego John Deere Gator HPX Ride on...
you probably have a disconnected motor, follow the steps below and check the motors to make sure they are connected
Oct 19, 2012 | Peg Perego John Deere Gator HPX Ride on...
How to remove bed
Jul 04, 2012 | Peg Perego John Deere Gator HPX Ride on...
My grandson's Gator runs ok in 2nd gear, but doesn't do anything in 1st or reverse.
one of your motors must be bad or unhooked, you'll have to remove the dump bed to get at the motors, then verify that they are both connected, or it could possibly be the shifter switch
Apr 28, 2012 | Peg Perego John Deere Gator HPX Ride on...
How do you get to the two motors?
Remove the dump bed, then the seats, on the frame of the gator that was under the bed will lift up. there you will see both motors and wires
Feb 19, 2011 | Peg Perego John Deere Gator HPX Ride on...
I am trying to assemble a john deere gator and do not have the instructions. I am stuck at the cargo bed. Where does the red pull to dump the bed go?
hope this helps
May 21, 2010 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
558 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
