Question about Durabrand DWT1905 TV
Channel setup my tv wont get the cable channels and ive done the auto channel setup and everything. what can i do because this is my sons tv and i need it fixed so i can reclaim my tv
  • mommab2230 Jun 16, 2008
    is there any other way i can set my sons tv to cable. i dont see it when i do the auto channel
    how should i tune the tv
    President:
  • 2,712 Answers
The cable will have to go into the set top box and from there to the TV..
Check that first and let me know how it goes..
Posted on Jun 16, 2008
  • 2 more comments
  • Swilin Sampson
    Swilin Sampson Jun 16, 2008
    Also, if you have connected this way, you do not need to auto tune. Go to AV1 or AV2 channel, you should see the cable channels. Now you can scan for channels uding the set top box.
  • Swilin Sampson
    @punchbala: The gentleman just said he tried auto-tuning..read the question carefully before answering.
  • Swilin Sampson
    Check and see if the cable is actually sending a signal. Try connecting another TV set to the cable and see if that works, if possible. If the issue still persists after you have connected the setup like I said, then most likely it is a cable service issue. I would recommend you call your cable service providers and get them to take a look..
  • Swilin Sampson
    Listen, the problem is with the service provider, if all connections proper on your end. Just give them a call, and your issue will be sorted out Pronto.
    Please click on the "accept" button to validate my response. Thanks!
    Sergeant:
    Champion:
  • 230 Answers
For that you should tune your tv to get the channels try
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
The only channels available are throu ch 2-13, I have tried doing numerous auto searches. and have tried to restart it. I checked the cable, everthing is plugged tightly and nothing is frayed. It has done...
Make sure the TV is set for "CABLE" or "CATV" tuning. I forget on this model exactly where in the menus the setting is. Sorry. But it's usually in a general setup page, or part of the channel setup. If the TV is set for "AIR" or "ANTENNA" tuning, cable channels 14 and up won't be detected.
Jan 13, 2011 | RCA TruFlat 27F520T 27" TV
The channels won't work.
you can use another TV to test the cable.
Apr 30, 2010 | Samsung LN-R409D 40 in. LCD Television
My tv wont tune in cable
go to menu, find channel setup or cable type on menu.slect auto search
Sep 06, 2009 | Samsung TXL3276 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Feb 16, 2008 | Sharp 32R-S50 32" TV
Tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Jan 10, 2008 | Televison & Video
Durabrand DWT1905 TV Logo
135 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
