Question about Dell Latitude D600 Notebook PC
When booted p and then just go blackup its shows to restart normal or safe mode when done in modes it starts to show lots of scrolls for disk, drivers, and if started normal it will have the windows load, i cant get to nothing on the computer
  • 320 Answers
Check your memory card it might be malfunctioning. Remove it and if you have an alternate ram replace it .
Posted on Nov 08, 2010
My laptop is Acer and it is showing like "we apologize for the inconvinence, but windows is not starts successfully" and showing some options like safe mode, safe mode with networking, safe mode with...
Here's the step by step on how I fixed this particular problem:
First, boot the computer into safe mode with command prompt. To do this, start the computer, and immediately begin pressing the F8 key at one second intervals. You may have to press several times until the boot menu comes up.
Use your arrow keys to choose Safe Mode with Command Prompt and press enter.
The computer will begin booting. Lots of weird looking white text will scroll by and then the computer will ask you to login or give you a box saying safe mode is running, etc.
Click Ok to finish loading. A black command window will appear with a c: prompt.
At that c: prompt, type chkdsk c:/r and press enter.
Check disk will start to run but then it will say:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y for yes, and press enter. Then reboot the computer into normal mode. Chkdsk will start when Windows begins loading again. Let all 5 phases run and don't use or turn off the computer. (The chkdsk process may take an hour or more to finish.)
Chkdsk finds any corrupted files that are causing the problem and fixes them. Read the results of each phase as it finishes. During the final phase, it will notify you if it finds any corrupted files.
When the Check Disk is done, it will finish loading Windows.
May 05, 2014 | Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Wont boot up says a disk read error occurred. press ctrl alt del to restart. i do this and the same message comes up
your operating system files is corrupt, that's why your computer is showing you that message.Your computer cannot but except the it is repaired.
To repair your windows, you will need the Cd that came with your computer, that's what you will be needing in other to repair your system.
Also, you can still boot your system by booting in safe mode. To boot in safe mode, restart your computer and immediately, keep pressing "F8" on your keyboard, a black screen will come up and you will see a booting option, scroll to safe mode and press enter.
Once your system boots up in safe mode, you can restart your system and the problem might be solved.
Take care.
Jun 01, 2010 | Toshiba Satellite A135-S2386 Notebook
Screen black on reboot
start the computer and when the computers splash screen shows (dell) etc. tap the F8 key repeatedly until you see the multiple startup choices. Scroll to "safe Mode with Networking" and select it, you will see the operating system listed as the target operating system, click that (hit enter) start in safe mode. When it boots do you see the screen with no problem? if so then the resolution may be wrong on the normal start up. On the dektop in a clear area free of icons, right click and scroll down to properties, click on settings, then move the resolution slider to either 800 X600 or 1028 X 768. click on yes to change the settings, restart the computer by hitting start > Turn off computer > restart. Reboot it normal mode (just let it boot as you would normally) If you can see the screen, you are all set, if not there is another issue to deal with.
Sep 03, 2009 | Computers & Internet
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
My LCD shows display in safe mode but no display in Normal boot.!
Its the problem with your display resolution. In Safe mode set it to 1280x800 and restart..
Apr 19, 2009 | Samsung SyncMaster 152 B 15" LCD Monitor
My computer completely rebooted and i cant get to the log in, what do i put in to get to the main frame
Try holding down the shift key after you hear the startup chime. This should start the Mac in Safe Mode and force some cleanup utilities to run. (Note that startup takes a bit longer than usual in Safe Mode.)
The login screen should show the words Safe Mode in red when startup is done. You can then restart and the Mac should boot normally.
Nov 24, 2008 | Apple iMac G4 Desktop
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
My computer starts but before booting it shuts down.
You may have lost part of your windows program. If you have a system restore disk, you can run a system restore and probably fix your problem.
Some of your windows files have gotten deleted. When windows gets to this point all windows knows to do is restart. A virus can cause this problem.
Stargazer
Mar 16, 2008 | Gateway 310S (2900621) PC Desktop
Laptop ?
First try to boot in the safe mode, by repeatedly pressing the F8 key. If it boots into the safe mode, press the start button, shut down then select restart. If it will not boot normally then, repeat booting in the safe mode and once booted go to programs/accessorys/system tools/restore the select a restore point date that the computer was functioning correctly and restore for that date. If it will not boot the safe mode restart the computer with the system cd disk and restore from it. BPCS
Dec 05, 2007 | Dell Inspiron 6400 Notebook
Dell Latitude D600 Notebook PC Logo
mukhtar21 shaikh
mukhtar21 shaikh
