Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Refrigerator stopped cooling
Since this morning, my Kenmore Elite ColdSpot refrigerator (Model # 106.53606202) has stopped cooling (both freezer and main compartment). Here is what I am noticing: * It is getting power since the lights are on. * The fan in freezer is blowing air but it is not cold enough. * Nothing inside the freezer or in the rear have frosted. * The compressor fan in the rear is working. * Water is coming properly from the dispenser. * I do sometimes hear clicking sound from the back of the refrigerator. Someone suggested that this could be because of a bad relay switch. Someone else suggested that the whole compressor might have gone bad. Anyone way to know for sure what the problem is? Is there anything else that could be wrong? Thanks, Madhuvan.
  • 1 more comment
  • Anonymous Jun 16, 2008
    Same problem.
  • Madhuvan Jun 19, 2008
    It was the problem with its relay switch. I replaced the switch and the fridge is cooling again.
  • coleen746 Aug 04, 2008
    We're painting in the kitchen. Moved the refrigerator and it stopped cooling. The repair guy put in a relay switch. It worked fine for a week. Moved the refrigerator again. It stopped cooling. It now has an additional noise like it's really trying to kick in but doesn't.
The usual cause of this kind of problem is a defrost failure. If the failure is not caused by a failed timer or coil, it is usually easy to fix-uself. Defrost cycle is usually by timer. But if the air flow was blocked by food items the frost build-up will be more than it can melt and eventually cause blocked airflow. THis can also happen when outside temperature changes dramatically.
To fix it, clear the freezer side, open the panel to see the evaporator coil. If you see the blocked frost, it is exactly the problem. Use a hair dryer to help melting it or leave it unoperational for hours until it is clear of ice. Now replace the panel back (this forms the airflow from down to up), restart the frig. Done. You will notice cold air in a few minutes. Actual power (freezing ice cycle) will build in 3-4 hours.
I am not a repair technician. I solved the problem by myself.
Posted on Apr 21, 2009
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Do you have any error codes on the unit, lights or digits, it may be stuck in defrost mode. Possibly a blown thermal fuse, try unplugging it for a few minutes and then plug it back in. If this is the problem, this will only be a temporary fix for a few hours till it hits defrost again. You will need to get this replaced
Sgt 48
Posted on Jun 16, 2008
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
I have a side by side kenmore coldspot model 52259100. The Refrigerator is not cold but the freeze is cold. Help!
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Kenmore Refrigerators
Kenmore coldspot model 106-54592400. The refrigerator is not getting cold enough, has been hovering around 45 to 50. The freezer is working.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 10, 2010 | Kenmore 50522 / 50524 Side by Side...
2007 Kenmore "ColdSpot" refrigerator turned up to level 5, still not getting cold enough.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 10, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore coldspot not making ice, and not cooling in the bottom
Your refrigerator is frosted up. Remove the inside panel of your freezer. Defrost the ice out of the coils and check the heater and bi-metal. If both are good then your defrost timer is bad. If one is bad replace and you have it fixed. Good luck.
Michael Anderson
(865)945-3808
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Coldspot Side by Side Model 51559101
I also have the same refrigerator model 106.56566400 and periodically when the power goes off in the house the refrigerator & freezer will stop cooling. Try pushing the on/off button located inside the refrigerator to the left of the digital temperature controls. Hold the button down, this turns the unit off, then press it again to turn it back on. This basically resets the refrigerator, and most of the time works to get the refrigerator cooling again. Try this first before calling a repair man.
Nov 22, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
711 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
