Question about LG 47LC7DF 47 in. LCD HDTV
Have audio but screen is completely black. no audio. Tv had been working perfectly for about 3 years. unpluged it for a couple of hours but did not help.
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 11, 2010
  • LG Master
  • 8,457 Answers
Tv turn on now,have a picture flashes only a few sec. than died and have audio left only?Yes,than the tv have dead 2 long boards call the LCD inverter boards.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Posted on Nov 08, 2010
  • 320 Answers
There must be a problem with your power supply board. Check for any busted fuse or components.
Have a 4 year old flat screen Apex. Turn it on have audio but black screen. Checked, unplugged and re plugged everything. A couple of time the picture came back hours later and days later but not at all....
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 19, 2015 | Apex Digital LD4088 LCD TV
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
The power supply could be on the way to failing completely.
Aug 26, 2017 | Polaroid FLM-3201 Television
Half TV screen is black
you have a bad Y Sustain board or X Sustain board
undo the back (if you know how to deal with electronics) and with the TV unplugged disconnect one of the board and turn on, see if works or not and try with the other one till find out wich one is.
Fosg2000, Rate me
Apr 13, 2010 | Philips 42PF9830A 42 in. LCD Television
My tv blinks from regular picture to a black screen continuously.
your tv is on the blink.
remove the back panel of set
on the crt pcb board you will find a wite or black pot.
turn it up or down while set is on this is the G@ voltage ajustment.
you might get 3 monts to a year of extra life from your pictor tube by doing this.
regards,
daniel.
Dec 23, 2008 | Sony KV-32S42 32" TV
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
The set is almost 10 years old and has always worked perfect until today. . .
It soulds as of your solder joints are getting old and starting to crack. If the screen goes completely black then I would resolder all the major solder joints on the main PC board, and if you mean that the screen goes to all snow (as if the cable went out) then I would also pull the tuner and resolder the joints inside it too. If you do not have experience soldering on small PC boards then allow a qualified tech to handle it for you. The fact that it works sometimes means that all major components are fine and the repair shouldnt cost too much.
Jul 13, 2007 | Toshiba CF27H50 TV
LG 47LC7DF 47 in. LCD HDTV Logo
132 people viewed this question
Steve Allison
Steve Allison
