Question about Dell W2306C 23 in. HD-Ready LCD Television
I have a picture but no sound, - Dell W2306C 23 in. HD-Ready LCD Television
  • 4 more comments
  • STEVEN QUIRIE Nov 08, 2010
    THE TV IS CONNECTED TO DIRECT TV BOX BY COAX, IS THE TV TUNER CARD THE PROBLEM
    DO YOU THINK THE TV TUNER CARD IS THE PROBLEM, i HAVE GONE THROUGH THE SET UP PROCEDURE, BUT IS HAVE NO SOUND. THE TV IS CONNECTED TO A DIRECT TV BOX WITH ONLY A COAX CABLE
    DOES THE TV TUNER CARD CONTROL THE SOUND ALSO?
    HELLO
    DOES THE TV TUNER CARD CONTROL THE SOUND AND PICTURE INPUT
  • STEVEN QUIRIE Nov 09, 2010
    READ THE PROBLEM......
  • Dell Master
  • 1,606 Answers
On a lcd tv this is usually a problem with the back light or its power supply (inverter board). If you look at the screen with the tv on you should be able to see a very faint ghost image. This will be a normal tv image but hard to see. You may have to get quite close and off to the side before you see it.
You can repair this if you are comfortable with electronics. The backlight just plugs in. I'm not 100% sure about the inverter board on this model. On some they are separate but on other they are part of the main board. If they are separate then it can be worth fixing. If its part of the main board it is cheaper to buy a new tv.
If you contact Dell to find any repair shops as well as where you purchased it from. They might also know where/who to talk to locally. Get an estimate first, and know what a replacement is worth. It's also worth checking to see if you have any warranty either from Dell or the store before doing anything.
Posted on Nov 08, 2010
  • 54 Answers
What are you connecting to it.... common problem is connecting av audio jacks and HDMI cables at the same time.
  • Ryan Hopkins Nov 09, 2010
    not sure about the tuner car i would say your issue is with the commection i would use av audio jacks to connect from the box to the tv that is how it is connected in most cases or with a HDMI cable
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
Playback movie pictures or sound
Movie pictures can be played back with the camera, but not sound. However, when the camera is connected to a TV, both movie pictures and sound can be played back. For playing back movie pictures or sound on a PC, the QuickTime™ 4 is required.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Dell W2306C 23 in. HD-Ready LCD Television Logo
53 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
