Question about Kenmore Ovens
My oven will only bake something on 500 degrees or broil.
  • 1 more comment
  • flarrn Nov 08, 2010
    Kenmore model number is 9114552091
    I have a Kenmore electric oven model number 9114552091 and can only bake on 500 and broil. What part do I replace?
    Kenmore Model #9114552091
    President:
  • 2,777 Answers
This is usually a problem with the control module.. basically the brain of the unit. What is the make / model of your oven?
Please let me know and I can help you out here.. just reply to my answer here.
Thanks
Tim
Posted on Nov 08, 2010
  • Tim Grayson
    Tim Grayson Nov 08, 2010
    It does not appear to be available anywhere online currently, it is the control panel module... the actual "brain" of the device. You may want to check with local repair shops to see if they can order it for you, everywhere online is out of stock on it and won't let you "back-order" it which is a bad sign. It may not be available any longer for whatever reason.
    Tim
  • Kenmore Master
  • 3,247 Answers
Happy to work this throgh but need the full model number of the oven.
Could be something wrong with the thermostat.
  • Sam Nov 08, 2010
    wondering why you rejected my solution when I was still asking the model number.
    cmmiuser01
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Top element doesn't get red hot on bake but does on broil is my controler bad
The top element (broil element) will come on when you put it in bake only to help the oven temp get to the desired setting. If your temperature is reaching the right degrees you shouldn't have a problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 02, 2010 | Kenmore Ovens
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Model # 911-41065
Hey lmount
Your problems seem to be a problem with your oven controller and more specifically it seem to be a problem with the relay on the unit. The contact seem to be welded (stuck) together.
If the contacts for the Broil does not come loose the Bake will not work
Also as the broil will not be controllable as it will always be on
Regards
Sep 04, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Ovens Logo
51 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
