Trying to get the tv that was given to me to register all inputs instead of just ant a and b
    President:
  • 1,779 Answers
In set up they normally do not include avi's and aux inputs into the channel memory.
Posted on Jun 16, 2008
Im trying to hook my denon stereo to my tv... can you help me??
What inputs does the TV have?
Otherwise experiment with these options:
DENON---------->>-------TV
Stereo jackplug phones out->>-RCA phono inputs.
RCA phono outputs->>-RCA phono inputs.
Stereo jackplug->>-AV.RF converter RCA phono inputs->>-ANT.in.
RCA phono outputs->>-AV.RF converter RCA phono inputs->>-ANT.in.
Nov 29, 2017 | Denon Audio Players & Recorders
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Digital converter box worked with RCA analog TV and outside antenna. Had to unplug both for some work in house; when we plugged everything back in, there is no digital input. I checked everything over many...
Make sure you have an ANT. connected to the INPUT on digital converter box....then OUTPUT that signal to the INPUT of your TV....put TV on channel 3 or 4 or put TV on VIDEO if using red, white and yellow wires...power up and program converter box for channels....should work... if not try a set of rabbit ears instead of outside ant.
May 19, 2010 | Televison & Video
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
I have cable and when i plug it into my tv i only
The tv will only process cable channels when set to 'ant cable' . After the scan, you should be able to view all channels provided on the frequency.
If you want more cable #'s, you will have to pay for those or get a cable box. If you don't find your local channels in the lineup, you will have to use a switcher, or hassle with unplugging and plugging the antenna. This is true for ATSC broadcasts. Please give feedback if this helps. Or tell me more.
Sep 27, 2009 | Mitsubishi WD-60735 Projection Television
Bad cable input connector?
try use vedio input for work....or use vcr ant in vcr vedio output to tv...
no need replaced tv
Aug 13, 2009 | Televison & Video
My Ant A Input Not Working
Good Day, babt;
TRY THIS:
MAY ONLY BE ABLE TO SELECT ANTENNA A AND B. WITH THE REMOTE CONTROL PRESS MENU, SELECT "SET UP" AND THEN "AV CONNECTION HOME THEATER" SET "AV NETWORK" TO "OFF" AND "TV LOCKED TO INPUT 1" TO "NO" THEN EXIT THE CUSTOMER''S MENU, TURN THE UNIT OFF UNPLUG IT AND THEN PLUG IT BACK IN, IF THE PROBLEM RETURNS AN E2 RESET IS NEEDED. ACCESS THE OPTION MENU BY PRESSING "MENU 1, 3, 7, 0", USE THE ADJUST BUTTON TO SELECT "E2 RESET" AND PRESS "QV". IF THIS IS NOT RESOLVED BY THE E2 RESET REPLACE THE EEPROM, IC701 PART # 275P163010. THE E2 RESET IS ALSO NECESSARY AFTER REPLACEMENT OF IC701.
Good Luck, big IRISH.
Aug 06, 2008 | Mitsubishi VS-50603 50" Rear Projection...
Ant A and ant B
There should be 2 buttons labeled Input, in between Volume and Channel. Press up on Input. If you are using a remote different from the one that came with the TV, then look for a button labeled 'Input' 'Int' or 'Mode' somewhere along the top.
Mar 29, 2008 | Mitsubishi CS-35405 TV
"ant A" and "ant B" inputs go black when the tv is first turned on.
Try opening that "Ant A, B" device and apply some fresh solder to all the components inside. Also you can try to by-pass that device using the connector below. One end connects the cable in and the other end connects to the circuitry inside the TV.
Jan 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Input problem
your tv is set to "Home Theater mode" . Use "menu" key on your remote, go to "advanced feature", then go to "use home theater" then hit "cancel" to return to standard mode. If this does not work try unplugging the tv for 4 hours to return to factory default settings
Nov 07, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
