Question about Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater
I need a replacement thermocouple for ML250TPA Propane Wall Heater 25,000 BTU
I have a two year old Redstone 30,000 BTU propane wall heater. There is a lot of dust behind the unit. After running for awhile on the 2 setting, it shuts down and the pilot is extinguished.
If it is a wall unit, it has an over temp safety switch which is most likely tripping from dust preventing proper airflow across it . A good cleaning should cure this.
Feb 04, 2015 | Heating & Cooling
Change thermocoupler on all pro 50000-85000 btu heater
If you have replaced the thermocoupler and it still wont stay lit then replace the gas valve.
Nov 18, 2014 | All-Pro Heating & Cooling
I need a thermocouple for a dyna glo natural gas wall heater
Billy here's a link to A & B Sales. They have what you're looking for. Whether your heater is Natural Gas or Propane makes no difference when it comes to thermocouples.However the length of the tubing does when it's a wall or stand type vent-free heater.
http://www.aandbsales.com/2.html
Hope this helps you & thanks for choosing FixYa.
Sep 21, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I own a Comstock-Castle Range model C330-11.It has been converted to use propane. It has 4 burners @ 13,000 BTU ea and a griddle @ 20,000 BTU on the stove top. It has a single oven with no broiler @ 25,000...
Castle ranges don't require a electrical plug. If converted to LP/propane make sure the water column (WC) is set to 10 inches. If it is less you will have pilot light problems even if the thermocouple is strong. If set at 10 inches, most likely problem is the thermocouple. Correct replacement at Castle is approx. $25. The manual for current ranges should cover most issues but the Castle stopped making the C series ranges in the 80s. All controls and most parts are still available.
Jan 19, 2011 | Comstock-Castle 2F330-36 Kitchen Range
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I have a rllp35a propane heater and it will ignite
either the thermocouple is bad or the pilot flame is not hitting the thermocouple .if the flame is hitting the thermocouple correctly it is most likely that it is bad and needs to be replaced
Mar 01, 2009 | Reddy Heater-30-55,000 BTU Variable
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
New heater pilot will not stay lit
gas and fire, I would return it before you blow something up.
Oct 03, 2017 | Ace Hardware ML250TPA Infra-Red Wall...
Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater Logo
61 people viewed this question
Top Ace Hardware Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
