Question about Dell Inspiron 6000 Notebook
Wont start up
I have a dell inspiron 6000 and it is only 3 years old. When i try to start it, it won't even load. We have tried to reformat it but it won't allow us to do that. I have no idea what happened it, it was working perfectly until 1 day it just stopped turning on.
  • 1 more comment
  • rachelelynn Jun 16, 2008
    it said that the start DST short test failed
  • danimeli1405 Aug 20, 2008
    my dell inspiron won't turn on at all? it does nothing. no power, no lights, no noises. the battery is good and the power cabale is good to but the laptop just won't turn on at all.
  • Mandeep  Singh
    Mandeep Singh May 11, 2010
    Hi Rachel,
    Could you be more specific on the problem, ie. are you getting power to the system and does it stay on ?
    As you have written, that you tried formatting but nothing happened , did you get any error while attempting to do that ?
    Try the following steps
    1. Tap on the F12 key slowly five times, after you power on the system and see the DELL logo screen
    2 You would get the Boot menu.
    3. Run IDE drive diagnostics or go to the Diagnostics option, if there is an error with the hardware the same would let you know
    Thanks
    mandeep
  • 98 Answers
That usually means the file system is corrupt.
Posted on Jun 18, 2008
  • Dell Master
  • 1,183 Answers
Follow any of the two wizards in the list that closest resemble your problem
http://tinyurl.com/5b9mdo
Posted on Jun 16, 2008
  • 62 Answers
Put on recharging at least half an hour.
Before, try to take a battery out and firmly clean contacts for battery.
If you have more questions email me on annj4215@gmail.com
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Just purchased a new 160gb Hard Drive for my old Dell Inspiron 6000; originally it was only 60 gb. I tried to install it, it said "not able to read HD". Actual connectors look a little different. Any...
Well the old Dell takes ATA connections. Newer laptops are SATA. Which did you buy?
A new disk drive needs to be partitioned and the operating system needs loaded. Did you do that?
Did you back up all your data to an external device so you can load it on the new disk?
Sep 16, 2010 | Dell Inspiron 6000 Notebook
Inspiron 6000 Reformat Nulls Modem
Go to Dells support site, link is below and put in your model laptop, then choose your operating system, there will be a list of available drivers you can download from them. I will try and give you the direct link below. The below is a direct link to Dells modem driver. Copy and paste to your address bar.
http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&deviceid=6685&libid=20&releaseid=R104087&vercnt=2&formatcnt=0&SystemID=INS_PNT_6000&servicetag=&os=WW1&osl=en&catid=-1&dateid=-1&typeid=-1&formatid=-1&impid=-1&checkFormat=true
Jun 25, 2010 | Dell Inspiron 6000 Notebook
Wiped hard drive and now must reinstall OS and programs.
if the disc you have has scraches on it then your disc wont run,you can have the disc reface for about $5.or try this wash disc with a very soft cloth under runing hot water [not to hot] dry quickly [soft cloth]and try it again while disc is still warm.had to do this myself with my dell oem disk.
dt
Dec 07, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000: No Boot Up after BIOS loads
You can download a small program called memtest 86 which is an ISO for creating a bootable cd that will test the ram. You can get it from: http://www.memtest86.com/download.html
Also the HD may be the problem even if the BIOS can see it. Pull the HD and try booting from the xp disk again.
Hope this helps
May 01, 2009 | Dell Inspiron 6000 Notebook
Inspiron 6000 wont load up
Does the keyboard respond to any of the caps lock or numlock buttons when pressed ?
Mar 02, 2009 | Dell Inspiron 6000 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Problems identifying and loading dell inspiron 6000 drivers
Go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag",(serial number) of the 820 laptop. Dell keeps a listing of drivers for every customer's computer they sell.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 18, 2008 | Dell Inspiron 6000 Notebook
Dell inspiron 6000
On ac power when you hit the power button, if there are no lights, it could be the power supply. If there are lights, try starting it without the battery, ac only. If there are lights and it still doesn't start after removing the battery, try a different memory chip. On Dell machines the battery can acquire a dead short causing it to not start. Also if the memory chip/chips have gone out it will cause it not to start. If it still will not start after these three it's a motherboard problem and will most likely have to be replaced.
Jun 15, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
100 people viewed this question
Alun Cox
