Question about Weather King 10AJA4201AH Air Conditioner
Outside makes loud noise
The unit outside makes a loud noise & blows cool air. For the last 2 years we have had to put freon in it. We were told we had a leak in the A coil. We just paid someone $996 to fix that. Now our unit is loud & blows cold air & inside is not cooling off. Right now it is 80 degrees in our house & the air conditioner is on & fan is running outside. HELP PLEASE!!
  • Anonymous Mar 27, 2014
    overhead rooftype air conditioner
  • 828 Answers
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Posted on Jun 16, 2008
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
I have 2 seperate Achiever AC-seer 10 units installed 6 yrs ago. One cools downstairs, the other upstairs. I have never used them before. They have been exposed to heavy snowstorms over the years in...
No Freon doesnt evaporate the only way you have to charge an A/C unit is if it has a leak somewhere in the system. It sounds like your compressor is locked up I would try installing a super boost to the Condenser (outside unit). Let me know
Jul 26, 2011 | Ruud Matching Split Air Conditioner
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
S40 with 80k- ac sucks!
If you have a leak in the system all the freon would leak out. Purchase a can of leak detector put in engine. Directions on how is on the can. If this shows a leak have lead repaired and new freon added. Could be compressor going out. Bought one on Ebay for $100 vs $300 from Auto Zone.
Jun 29, 2009 | 2006 Volvo S40
It takes more then 30 minutes to drop 1 degree after the outside unit was charged to 200 psi of freon last year on may 28 2008
Air filter needs replaced, if the air is low flow but cool out of registers.
Need to find the leak in freon line if air is not cool.
Clean outside unit if either one applies.
Jun 04, 2009 | Heating & Cooling
Loud AC unit outside trane high efficiency xb1000
The noise could be the fan trying to pull air through the condensor. Service cleaning should improve cooling and lower noise level.
May 21, 2009 | Heating & Cooling
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Weather King 10AJA4201AH Air Conditioner Logo
428 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
