Question about Garmin nuvi 255W GPS Receiver
When i plug my gps in. it goes to the front screen were it tells me not use it while driving or whatever, and then it freezes and wont let me press anything.
    President:
  • 1,111 Answers
If your plugging it in to your computer via the usb cable, its suppose to do that..you cant operate it while connected to the pc, thats for charging and data transfer only...
if its happening while plugged in to your home or car adapter, the adapter is either faulty or not the right one for the 255w.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Nov 08, 2010
My Garmin 1490 LMT goes to white screen with "press dot" only its not to calibrate it bc no matter how many times you push it it wont go, it wont get out of that screen so I can't do...
The white screen indicates are internal error. It keeps telling the unit to go into calibration mode. The item will need to be sent to garmin for repair. 1-800-800-1020. If your unit was purchased recently (less than a year) it is covered under Garmins limited Warranty.
Sep 25, 2011 | Garmin Nuvi 660 GPS Receiver
Uniden trax 430 frozen
I have had a similiar problem with my Trax 430. The screen freezes at the system shut down stage. I have to plug it into the computer via the USB cable. It then recognizes the computer and attempts to do an USB update. Then just unplug it. It should work but not a practical solution when you are driving about.
Jul 10, 2009 | Uniden TRAX-430 GPS Receiver
I just received my Garmin for XMAS and it was working fine but now it just seemed to not charge. Then the little pic on the front shows the GPS connected to a computer desktop. HELP! Amber Fader
Does it turn on at all? Try to charge it on car adaper then, when it will turn on, try this.
The picture is displayed while it is charging through USB cable and you can't normally use GPS.
Turn the GPS on without the USB plugged in, then press the Battery symbol for about 10 seconds, until the test screen appears. Then plug in the USB.
Screen will tell you percentage of charge, and if it is charging.
***Make sure you press EXIT before unplugging the USB cable. Press EXIT, turn GPS off, then remove the cable is safest way
On the bottom you should see "USB type" if nothing is there, it may be the USB port on your computer. Try it again with a different port
Jun 12, 2009 | Garmin nuvi 255W GPS Receiver
Cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Feb 08, 2009 | Garmin nuvi 350 GPS Receiver
Garmin GPS-V freezes up
The update from Garmin seems to have cured the problem!! All I did was the reload.
Thanks velomaster!
I've had my Garmin GPS V for almost four years and loved it ... until the dreaded "black line" showed up. I considered replacing the unit but couldn't find anything that would give me the features the GPS V gave me (elevation, ground speed, grade change) and I didn't need a color screen display as an alternative. I'd even bid on a few replacement units on ebay. I was just about ready to bite the bullet, send it in to Garmin and swallow the $125 rebuilt charge when I ran across this thread. After the update it hasn't locked up and as a bonus I have more detail than I had before!
http://www8.garmin.com/products/webupdater/
If you have a GPS V you really do need to do this.
Mar 17, 2008 | GPS
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Magellan roadmate 700 gps not working
Jossie, The cable that connects your hard drive to your main board could be loose. If it's not loose, then it's your hard drive. The only thing you can do (if it's not the cable) is send it in for a new hard drive. Unsure what the costs will be but the magellan logo screen is produced from memory on the main board while anything after that is when the hard drive takes over. -Daniel
May 27, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan 700 "freezing"
okyboky, Once you turn on your unit, the Magellan splash screen or animation is produced from the flash memory. To my experience anything past that is dependent on the hard drive. So, your unit is freezing up as soon as the user menu is displayed without any response to pressing keys or touch screen right? Have you tried (at the user menu) pressing "-" key and the repeat button (on top of unit) to enter the "secret" menu? if you can do that, then select reset user data. That seems to fix numerous problems. If you absolutely can't get past that screen, or get any type of sign of intelligence from it then your hard drive is either corrupt/damaged or you could just have a cable not secured. If the above doesn't work, and you don't plan on sending it in for repairs, then open it up and make sure the cable from the Hard drive to the main board (large board) are fastened. Of course, being grounded would be helpful in this situation and also be careful when you first open up the unit as the RF cable needs to be unplugged before seperating the two sides (front/back). Good luck and let me know how it turns out. -Daniel
Mar 19, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
