Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Rinnai 557FTR Heater
Hello I really need some help my heater wont stay on it will come on when I turn it on but only runs for approx 10mins then beeps a lot and stops with the 2 red lights flashing? I cant find my manual and dont know what to do
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Make sure the circulating fan and cover in the back is spotlessly clean. You should get a Error code that will help you find the trouble
Good luck,
Tom Hawkins
hawkins111@gci.net
Posted on Jan 06, 2009
The heater you have is not sold by RTA INTERNATIONAL. We are the distributor for GARDENSUN patio heaters. From what you say, I would think you have a pressure problem or a bad thermocouple. Check all your fittings by spraying them with soapy water. Be sure you turn on your gas to check.
Check the tip of your thermocouple. Be sure the tip is tapered and not burned through on the tip. If it is, you need a new thermocouple.
Posted on Jun 16, 2008
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Feb 21, 2015 | Rinnai Heating & Cooling
I cant get my child lock off on my rinnai gas space heater 557ftr
Jo, press the up and down temperature buttons simultaneously and hold for 3 seconds. This will release the child lock out feature. If you ever want activate it again, do the same thing, I just mentioned.
Hope this helped you and thanks for choosing FixYa. Cheers ...
Sep 17, 2011 | Heating & Cooling
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rinnai gas heater loud noise on ignition
It may be, Rinnai suggests a maximum length of about 13 equivalent feet of venting including elbows. Add 6 feet for every 90 degree elbow. If the vent is longer than this it is taxing the combustion fan motor and it will start giving you error codes and will not ignite. Remove the trim panel from behind the heater and find the flexable air intake pipe. Temporally remove it from a fitting and test the unit a few times to see if the unit starts quieter. This procedure will be taking room air into the heater for combustion and circumventing the direct vent feature of the heater, not a fix. Have you had the gas pressure tested? It gould be that! You may wish to consider relocating the heater and fire your installation contractor for putting you in this predicament, not Rinnai.
Nov 05, 2009 | Heating & Cooling
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Avenger 25TR Model Gas Heater
I just fixed this problem for my parents. All you have to do is hold the up and down arrows that sorround the power buttom for 3 seconds at the same time and the key symbol should dissapear and make a slight beep. Then you should be able to use the heater as normal =]
May 03, 2008 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
362 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
