Question about Maytag MSD2454G Side by Side Refrigerator
Maytag MSD2454 SIDE X SIDE
The freezer size freezes up and water drips on the floor. How do I eliminate this problem?
  • MattLa Jun 16, 2008
    I have water on the floor next to the freezer side and the bottom of the freezer has a thin sheet of ice on it. I think the ice in the bottom of the freezer melts during the defrost cycle and leaks onto the floor. How can I prevent the ice from forming? This just started about 2 weeks ago.
  • mbandrews Jul 03, 2008
    Water is freezing on the bottom of the freezer compartment. If I don't chip it off 3-4 days, the water will leak out on to the floor. I have been on hold with the Maytag hotline for over 1/2 hour and this is the 3rd time I've tried. I am calling an independent repair service.
Hi I have had this also happen,I need have a repair man come in to fix this and was told it will NOT happen again.Surprise!! It has happened again.But I was told that thee is a plug in the freezer side that get frozened up so this time I had to take everything out of the freezer,the bottom rack,then un-screw the back panel,in the bottom there is a small hole and this is were it is freezes up.Why?? I still do not know,but once again I have a call into the repair man again.But this time I did notice were the coil sits next to the freezer wall,it has melted,as if a fire had been there,So No I am not a happy camper myself.But good luck with yours.
Posted on Jun 24, 2008
I have a Maytag Refrigerator mzd2752gr and it leaking water inside freezer compartment. Water then freezes and collects at the bottom of the freezer. When the ice starts to melt it drips out at the bottom...
First thing is to remove the ice from the freezer floor. After that rermove the lovxer basket and directly behind that you will see more ice below the freezer back wall. The problem you have is a cogged drain line. Remove the remaining ice there and located the drain hole, which is normally located in the center of the trough you see. On some models you may have to remove the back wall as well to get to it. After located the drain hole, thaw it out using hot water, a hair dryer, or carefully using a screw driver to tap into it to remove the ice blockage. Once you can freely pour water down the drain hole, you'll be good to go.
Nov 05, 2010 | Maytag MZD2752G Side by Side Refrigerator
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water frozen in the bottom of freezer on double door Maytag frig.
Shut the water off for one before it ruins all your floor. It probably has frozen and broken a line or the valve. You can go to this site and get a drawing on your fridge and parts if you need them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag MSD2454G Side by Side Refrigerator Logo
492 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
