Question about Haier Portable DVD Player PDVD7
The battery doesn't seem to be holding a charge. Not sure what I am doing wrong. When I charge the battery should the device on on or off mode?
  • Haier Master
  • 8,457 Answers
When u charging the battery of the portable DVD player,DVD player it should be in the off mode and have a solid LED light indication on.
Posted on Nov 08, 2010
Battery doesn't hold charge for more than a week
All batteries will eventually fail to hold a charge. The battery chemistry and how you charge it can change how long the battery will last. The DMC-FS4 has a Lithium-ion battery so it shouldn't have as much of the memory issue of older rechargeable batteries. (This is the "you routinely recharge the battery when it's at 50% then it always stops working at 50% charge" problem.)
How old is your battery? Eventually you will need a new battery but the time to replacement will depend on the number of recharge cycles. With a Li-ion battery, I'd expect several thousand recharges before failure. Temperature and usage will effect this. The battery does lose charge even when not used.
Be careful, some versions of the firmware look for Panasonic's specific batteries or a "that match the Panasonic rigorous specs".
I've seen a few devices where the charger failed before the battery. If a new battery doesn't seem to be charging, replace the charger. I hope this helps.
Oct 18, 2012 | Panasonic Lumix DMC-FS4 Digital Camera
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Huawey g6600 doesn't turn
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 29, 2012 | Other Huawei Passport G6600D Unlocked Dual...
Battery not storing power
Hello
As time goes by the battery doesn't hold the same charge as it used to.
The only fix is to replace the battery with a new one, also make sure the power mode is set to power save mode in windows so that battery lasts longer.
Mar 01, 2012 | Computers & Internet
My Sloney E reader doesn't seem to be taking a
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
Feb 24, 2012 | Sony Computers & Internet
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Concerned.
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
My garmin shows a computer picture and doesn't switch on anymore!
Connect it with the USB cable to a PC / Mac - does it communicate with Mygarmin.com? If so look for a software update and load it. Make absolutely sure it's connected to external power - so the battery won't die when updating. Then wait for it to restart.
If no connection then hold the power button for more than 20 seconds - this triggers the auto reset.
If that doesn't help - let it sit like this till the battery has been drained. Then try to restart while charging it.
If still the same - let it drain again and while pressing the On button, hold the lower right corner of the screen for at least 20 seconds. This will trigger a master reset - reverting back to factory mode. It will erase all user data.
Jul 04, 2011 | Garmin GPS
I have a HK TC30 remote control that will reset itself, displaying "Testing" and then indicates that the remote thinks all devices are off.
Try re-loading the firmware again through safe mode. 1. Take out the batteries from the remote. 2. Turn on your computer and hold the off/on button and connect the USB cable to the computer and remote. 3. The remote display should say "Safe Mode Requested". 4. Start the HK software and login, then click on Support. 5. In the download section, click on firmware and then proceed to update the firmware again. 6. After you update the firmware, you will need to re-download your configuration again and update the remote.
Feb 22, 2009 | Harman Kardon Televison & Video
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
Haier Portable DVD Player PDVD7 Logo
295 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
