Question about Baumatic Dishwashers
I have just moved into a house which has a Baumatic BAFD62SS dishwasher. The first time I used it (which was yesterday) it ran for 7 hours!! When it finally finished, I checked the filters and they were quite clogged up, so cleaned these, but have not tried it again since. Could this have been the problem? Karen
jsrock516
  • 5911 Answers
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Posted on Jul 10, 2007
SOURCE: Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Posted on Dec 28, 2007
  • 1462 Answers
SOURCE: baumatic dishwasher accident
flush out as much as you can but you may have damaged the resin in the softener in which case you will have to replece it
Posted on Oct 20, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
  • 188 Answers
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
Baumatic Dishwasher BD1632
the milky spots on the glasses is actually from hard water. www.dishwasherfilter.com has a product out that filters the hard minerals before they enter the dishwasher. this will solve your problem and is guaranteed or your money back. you will love the way your dishes look.
Jun 10, 2013 | Dishwashers
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dont know how to clean the dishwasher
go to the dishwashers brand site,click help for your solution.
Jan 05, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
DISHWASHER WONT STOP UNLESS YOU MANUALLY TURN IT OFF
Wow, I am just wondering is the water inside the dishwasher warm or hot? Or is it cold? IF it is cold it could be that the unit is trying to heat the water usually to 120 degrees.If it is hooked up to a cold water valve from your house this could be the problem. Or it is the heating element,.
Jan 05, 2009 | Dishwashers
Dishwasher won't run cycle and no water is entering machine
This sounds all to familiar. I had this problem once and it was valve that was closed and would not open. The cause was lime in the water that built up over time. This was an unnecessary expense. Is the water in your area generally hard? Once I replaced the valve, it took care of it.
Dec 25, 2008 | Asko 24 in. D3350 Dishwasher
Baumatic DW9
Hi - You can download the manual by clicking the link underlined in blue below:
Baumatic DW9
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Baumatic 23 in. BDW9 Built-in Dishwasher
Dishwashers Logo
132 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
