Question about Ovens
6 yr old Thermadore C Model electric double oven - top oven heats ok; bottom oven only heats to 125 degrees.
  • John R. Plunkett Nov 08, 2010
    The item # may be C272-10211. Or it may be a SC272. As stated previously, it is an electric oven.
    Would an electric ove have an ignitor??? Thought that is for gas. Funny that the bake element would go out. We haven't used the oven more than15 times in 6 yrs. Could there be any other problem?
    If it is the bake element, how do I replace it? If I pull the oven, will I be able to get at the element?
    President:
  • 1,891 Answers
Model # is not complete but if this is a gas unit i would think that the lower ignitor is not igniting the burner so replace the ignitor and if a elect unit replace the bake element . . if more help is needed i need a complete model # . mm hope this helps mm
Posted on Nov 08, 2010
  • dennis dodge Nov 08, 2010
    bottom oven is only warm sometimes this is caused by the pre heat ( both element come on but after pre heat oly the back does . . replace the oven ignitor or bake element .. ..
    we have decided you have a elect oven so disregard the ignitor . if the oven only gets warm it may be the preheat that is doing it . this is done by using both top and bottom elements in the lower oven at the same time and when the sensor tell the clock it has reached it then the top is of and the bottom is off . . now elements are like light bulbs . you cluld buy a new one and it won't wrk . element is in bottom of oven . turn off power remove 2 screws and ut will pull out do not pull to far with removing wires . DO NOT LOSE THE WIRES ) then test the element . we need to know if it is bad or not befor we go it other causes ..mm feed back pls .
Rbd305pdb14,have error ( F5-E1) replaced controlled board, replaced touchpad, replaced sister board, replaced thermal fuse lower oven, replaced lower oven heat sensor, top oven works ok, lower oven still...
that's a bad door latch,if you use the self clean don't use it anymore,the oven gets up to 1000 degrees and damages the electronics in the oven,takes out the clock assy. the door latch things like that.part number WPW10195934 go here to see parts go here put model number in and look up parts,also you can check all the error codes down in bottom right hand side
https://www.searspartsdirect.com/model-number/RBD305PDB14/1198/0125300.html?searchType=modelSearch&q=Rbd305pdb14&searchTerm=Rbd305pdb14
go to upper oven and look at part number 22,you should have googled the error code before you changed out all those parts.
Feb 06, 2018 | GE JTP48SFSS Electric Double Oven
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Top oven glass in door is broken (thermadore).
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
heatman101
Mar 31, 2010 | Thermador C302U Electric Double Oven
Oven won't heat
hi, sounds like the heating element
Mar 07, 2010 | AEG U3100-4 Electric Double Oven
Older Thermadore) fan is ALWAYS on.
check inside for the techsheet on top panel. your thermistat of fan if faulty
Feb 11, 2010 | Thermador SMW272 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Ovens Logo
37 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
