SOURCE: dishwasher will not cycle. pump
Does the motor turn and is not stuck? If it is free, then you may want to get a tester. An ohmmeter and a voltmeter. Test the door switch with an ohmmeter. A bad door switch can cause problems.
There is also a timer that can cause some problems as well. You can test the power coming out of it with the meter.
If those test out ok, check for a hi-temp thermostat. That can be tested with an ohmmeter. Should be between 11 and 30 ohms.
If those check out ok, then it's on to the control board.
Partselect . com has parts diagrams and more if you need pics and diagrams of the machine.
SOURCE: My kitchen aid dishwasher will
check all cables especially the ribbon cables from the user interface to the electronic control assembly as steam from dishwashings will create small amounts of corrosion and inhibit signals to and from these 2 components,unplug each,inspect,and reconnect,if this fails,then replace the electronic control assembly located behind the user interface you previously replaced
SOURCE: hi, i am having an ongoing problem with my
Hi It may be
an issue with heater circuit, door switch or wash pump. If yes then please
reset the power to the dishwasher. After, 5 minutes check if you are still
getting the same error. If yes, then it is a water heating fault. To resolve
this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry -
Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy
saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3
minutes and then you press the Cancel/Drain button and allow it to completely
drain and reset. If this doesn't work then it's an issue with the wash pump not
pumping the water past the heater efficiently or due to lack of water to heat.
Please make sure that heater is not open circuited and is heating the water
efficiently. You'll have to check the heater using a multimeter; the meter
should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If
heater is fine then make sure water pressure is optimum and fill valve is
working fine. Hope this helps...please post back for further assistance. Daniel
Hi
First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the HEATED DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
Daniel
Hi
returns after its cleaned then it means that the control board has gone bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
