Question about LG WD-3274RHD Front Load Washer / Dryer
Need to replace drain pipe. How do I obtain a manual?
  • 27 Answers
Posted on Nov 08, 2010
Testimonial: "thanks fo thr prompt response"
Oil drain plug for 7.5hp briggs straton engine
If you're looking to obtain an oil drain plug -- your post doesn't actually say that -- I'd recommend your local hardware or plumbing or home improvement store. Briggs & Stratton generally uses standard iron pipe threading on their oil sump drains. You'll want a 3/8" IPT plug.
Aug 04, 2015 | Troy-Bilt Troybilt Horse 6, 7 And 8 Hp...
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
I need to fit a new drain hose to my Bosch Dishwsher Model No. SGS546A72/42 . Is this easy to do and can I obtain a diagram to assist.
not all models use the same size drain hose. you need to know what size the out put of the unit (could be found in the user manual or measure the outside diameter of the outlet on the unit.) also you need to know what is the size of the connection to the drain on the pipe under the sink or where ever it is located. it is also best if you know the length that you will need don't go short a little extra can usually be better than to short. with all of the above written down on paper go to the hardware store (I like Lowes) and have the store person show you what he has for your dishwasher. I like to put clamps on the hoses as it keeps them inplace and will eliminate future leaks.
Jun 21, 2011 | Dishwashers
1996 Nissan Maxima exhaust replacements
Yes you can obtain the parts from after market. The Flex Pipe is installed on all cars hows engine is built in transverse. if you accelerate the engine tries to turn against the crankshaft rotation. W/o flex pipe your exhaust will be broken after a couple of minutes. The flex pipe acts like an accordion and eliminates this small "turns".
Jan 27, 2010 | 1996 Nissan Maxima
Drain in back of frigde keeps freezing up but not blocked
this is a common problem. it can be rectified by replacing the drain pipe. it can be accessed from the back behind the condensor. you will have to cut open at the back to do the repair and once replced, reinsulate the insulation by using liquid foam obtainable from your local hardware.
Sep 06, 2009 | Refrigerators
Need to replace drain valve
The "welded nut" is the pipe fitting into which the drain valve or drain plug is screwed. It's usually brass and the valve or plug can be obtained through Sears or possibly and good harwarde store. Be sure to use pipe sealing compound or teflon tape on the threads when you re-install the valve or plug.
NOTE - THE AIR MUST BE DRAINED FROM THE TANK BEFORE REMOVING THE VALVE OR PLUG. ALSO, POWER SHOULD BE DISCONNECTED FROM THE COMPRESSOR!
Mar 04, 2009 | Craftsman Air Tools & Compressors
Air con smells when cooling
Check the location of your drain, it might be installed in a ditch or smelly location. Install "P" trap in the drain pipe pipe to avoid the smell coming back into the drain.
Feb 11, 2009 | Fujitsu 18C1 Air Conditioner
LG WD-3274RHD Front Load Washer / Dryer Logo
93 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Mike
Mike
reliableservice
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
