Question about Power Acoustik HDVD9 Car DVD Player
Is there a customer service number for Power Acoustik? I am trying to install headrest DVD but one on the output pin connectors has bent pins inside and will not connect to headrest cord. It's defective and I need another one asap. Thanks
    Director Badge:
    Uploaded 100 video answers.
  • 225 Answers
Here's the link for the return authorization form they have you fill out online:
http://www.poweracoustik.com/pa2006/form1.htm
Here's their contact information:
Power Acoustik Electronics
1550 S. Maple Ave. Montebello, CA 90640 USA
Phone: 323-722-3333
Fax: 323-722-1122
http://www.poweracoustik.com/pa2006/CONTACT.htm
Posted on Nov 08, 2010
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
Installed dual DVD headrests, they both get power to them because the buttons light up...one screen flashes white then turns black, the other screen stays white. None of the buttons do anything, not e
Sorry I can't help you but maybe you can help me. I also ordered a set of these Anbotek DVD headrest players on ebay a few months back and trying to figure out how to install them in the minivan. Did you get any instructions? If so how did you get power to them so they work? Any help would be appreciated. thanks
Jan 19, 2014 | TMI Products Vizualogic Headrest Pair...
How to fix the13 pin wier card in-- Soundstream VIR-7840NR
Hola...Por que dices que el conector no te coincide??
Si es el que entra en el radio hay dos tipos, uno con 24 pines y otro de 28 pines, yo tube un problema igual y compre el conector adecuado en la pagina de power acoustik.
Jan 23, 2013 | Power Acoustik NAVIBOX-1 GPS Receiver
Power Acoustik DVD headrest shows blue screen/red welcome on start, won't play
sd sa dsa das dasd as fasf as
[url=http://www.rezibis.com/]headrest monitor[/url]
[url=http://www.rezibis.com/]headrest dvd player[/url]
Jan 02, 2013 | Car Audio & Video
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
My l g monitor screen suddenly turned into pinkish colour..i dont know whats the problem..i did degaus also but no use..
Dear Sir
Welcome to Fixya Customer Support
We will Help You
Generally this problem arises due to faulty monitor Signal cable or by broken fins of VGA cable.check your monitor connectors for bent or broken pins. usually happens after swapping cables or monitors on a computer.you could also have a bad cable or monitor.
Is the monitor a CRT or a flat panel.... loss of one color is very common on CRT monitors, and could be a bad solder connection on the CRT driver board, or a bad video chip..... flat panel LCD monitors don't usually lose a color, although it is possible.... the most common failures on LCD flat panels is total power supply failure (no power at all) or display matrix driver failure (colored stripes across or down the screen), but a cable failure is also possible, like i said above, check the connectors for bent or broken pins..... there are 3 rows of pins...... at the widest side of the connector, there should be at least 3 pins next to each other on that row (sometimes there are 5), the middle row should at least have 3 consecutive pins as well (and again, there are sometimes 5)
the last row (the smaller side of the connector) should have at least two (but sometimes all 5) pins in it. the first row and last row of pins should line up vertically, and the middle row is offset a half a space, so from top to bottom, the columns of pins make a zigzag...... if the connectors are alright, then your most likely problem is the monitor..... if another monitor works on the computer, it's the monitor..... if another monitor has the same problem on this computer, then it is the video card (or the motherboard's video output, which is fixable by installing a video card)
once again we are thankful to using
Fixya Customer Support.
chandrashekhar
Jul 10, 2009 | Computers & Internet
Front power headrest removal
hello,you need to remove your rear seat,,look for your your headrest valve ,there is a lock pin with tension clip in headrest rod ,remove the pin,try to remove your headrest slowly,ty
May 07, 2009 | Mercedes-Benz 560-Series Cars & Trucks
Battery Charging
Perhaps one of the contact pins are slightly bent, best to remove the power lead from the wall, grab a magnifying glass ... and have a closer look.
A bent pin will appear to be out of line with the others.
The connector may also be worn in such a way that it will not make contact... no matter which way hold your tongue. :)
Take extra care when straightening the pin or pins.
Also a worn connector can build up a type of scum on the surface of the pin or pins, otherwise known as oxisidisation and corrosion or in simple terms ... RUST !
Carefully clean the pins with a Q tip dipped in methylated spirits and allow 5-10 minutes to dry, before reconnecting the charger to the DVD player.
The other possibility remains that the battery or charger may also be past it's used by date and may need to be replaced.
Jan 12, 2008 | Durabrand DUR7 Portable DVD Player
4 port belkin kvm
The things that usually go wrong with KVMs are bent connector pins (usually mouse or keyboard) or the switch itself. Inspect the mouse connector for bent or corroded pins. They are easy to bend and straighten, however, they will eventually break off if you do it often enough. If you find one that is bent the safest way to straighten it is by using a .7 diameter mechanical pencil. Remove the lead, and work the pin carefully into the pencil barrel. Once you have the pin inside the pencil gently straighten it by moving the pencil vertical. If it?s not a bent or corroded pin there isn't a whole lot else you can do other than try to get a warranty replacement or if its expensive enough, repaired.
Mar 20, 2007 | Belkin F1DK102P 2-port KVM Switch
Power Acoustik HDVD9 Car DVD Player Logo
185 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
