I'am using xp pro can I have my computer shut down at a sertine time each day? I'am using online backup and I would like to start the backup and go home with out waiting for the backup to finish.
  • Paul Townsend Nov 08, 2010
    Thank you, Thank You, Thank You. 1800 work great for me.
  • 13,433 Answers
Hey, sure.
You can bring up the run menu from start -> Run OR hold down the windows key and press R.
Now on the run menu, you can write commands to the machine. A command good for this task is shutdown.
http://ekse.pp.fi/shut.jpg
On the above picture you can see the usage of this command, its on a windows 7 machine so it will be a little different on yours.
Lets say you want to shut down the computer in 1 hour after you have left it. you would then write
shutdown
and then after it, press spacebar to add a space and then add /s
The /s command tells it to shutdown the computer.
so your command looks like this at this point: Shutdown /s
The above command would shutdown the computer instantly, we can set a timer, for this we use the /t command.
So now your command looks like this: shutdown /s /t
Now for the last part, how long do you want the machine to wait until it shuts down? for 1 hour you would enter 3600
shutdown /s /t 3600
the above command brings up a timer on your computer screen telling it will be shut down in one hour. Note that the time is on seconds. If you want to shut down in 2 hours you would enter 7200 and so on.
Let me know if you have further questions.
Posted on Nov 08, 2010
  • Ekse Nov 08, 2010
    You might want to add /f to the command to force the computer to shut down, incase a program is hang it might just hang there and stay on all night so
    shutdown /s /f /t 7200
    for example the above will force a shutdown at 2 hours after you have pressed enter or click OK on the run prompt.
    I'm sure you can use a calculator but, heres a time conversion table for you
    900 = 15 minutes
    1760 = 30 minutes
    3600 = 1 hour
    7200 = 2 hours
    14400 = 4 hours
    and so on. just add that after a press on the spacebar after the /t and your good to go
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
I have XP Pro OS and I didn't gracefully shut down when it said Windows shutting down. I pressed the power button to shut off manually because it was taking too long. Now when I turned pressed the power on...
If you're still able to access your start menu:
Start>All Programs>Accessories>System Tools>System Restore
Select "Restore my computer to an earlier time" and click next
Choose an available restore point, one of a time before the incident occurred. Then click next.
I'm not sure how long this will take but it will notify you of a successful restore.
Oct 28, 2010 | Computers & Internet
Windows XP will not shut down.
I don't know if you've tried this yet,but here it is just in case.
Click Start, and then click Control Panel > Performance and Maintenance>Power Options>In the Power Options Properties dialog box, on the Power Schemes tab, click the Power schemes drop-down list and select the power scheme that most closely matches how you use your computer.
adjust the System standby and System hibernates settings if you are not happy with the default selection. On the Advanced tab, you can adjust the default behavior of the power buttons on your computer. Click Apply>OK
Please rate this a fixya
May 21, 2009 | IBM IntelliStation E Pro 570 (689357U) PC...
Hi i have installed windows xp pro on an ibm personal computer 300gl am getting this error blue screen a problem has been detected and windows has been shut down to prevent damage to your computer i just...
you might want to run a backup and reformat the computer, or you can use one of the following programs that does a really good job in fixing blue screens, I'm a computer tech and i use this program in alot of computers.
http://www.pcbugdoctor.com/ , its free to scan, but you should consider buying it, great program.
http://www.download.com/ , download "ccleaner" cleans and fix your registrys this software is freeware.
there is also alot of other solutions, please get in contact with me if you continue to have issues.
Apr 16, 2009 | IBM Computers & Internet
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Pyrated copy of Windows EP.
hi, XP pro. installed by your asso. in a pyrated version and is not genuine copy. Such serial numbers are blocked by the MS for any updates or software from microsoft. However you can use it normally with all the programs except the special updates from microsoft.
thank you for the request
Aug 16, 2008 | Computers & Internet
Genuineness of MS windows XP.
hi, the XP pro. your associate installed on your computer is a pyrated copy which is blocked by microsoft. so you may not be able to install any updates from MS. However you can use it normally with other applications.
thank you
Aug 15, 2008 | Microsoft Computers & Internet
Automatically retarting when I shut down computer
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Jun 10, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
