Question about LG GC-051SS Compact Refrigerator
My Chefmate BC-50A Semi-Conductor Mini Refrigerator is constantly having problems. About every week and a half or so, I have to fix the fan because it has iced over to the point of almost not working. Is there anything I can do to fix it on a more permanent basis?
SOURCE: Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Posted on Jun 02, 2008
  • 958 Answers
SOURCE: I punctured the freon channel
you have to bring it for repair.
the repair that they would do if they know how to is to weld the puncture hole by aluminum brazing , they may want to check the oil in the compressor in order to be sure that no water have been sucked by the compressor from the hole in the evaporator.
evacuate the system and charge it with the right amount of the correct refrigerant.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
miket756
  • 2702 Answers
SOURCE: I have a Chefmate Mini Fridge - BC-50A that does
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Posted on Nov 19, 2009
  • 12173 Answers
SOURCE: NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL#
remove motor and use the numbers on motor for replacement most appliance, hvac,and electrical supply stores even online carry replacement
Posted on May 06, 2010
  • 3 Answers
SOURCE: will not cool light does not
unplug, take the back cover off.
Look at the circuit board.
at the top right of the board there is a fuse.
if it is blown, the frige is dead.
you will probily find that there is a brown burn mark
on the upper left side of the circuit board under an aluminum
heat sink. that electronic part probily overheated and blew up.
unless your electronics skils are up to it throw the frige away.
but if you are up to it unsolder it, bring it to frys electronics, and
get a new one. Good luck.
Posted on Sep 08, 2010
Semi conductor electric cooler
These people have a similar fan motor.
http://www.appliancepartspros.com/search.aspx?model=dts%20181%20cr%20dr%20ww
some semi conductor fridges use mains operated computer-type case fans.
Aug 06, 2015 | Furniture
Will not cool light does not come on when door is open Chefmate Model: BC-50A
Aug 25, 2010 | Refrigerators
NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL# BC-50A SERIAL# 060511869
May 06, 2010 | U-Line 15R Compact Refrigerator
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
Chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Jul 21, 2009 | U-Line 15R Compact Refrigerator
Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
I punctured the freon channel in the freezer compartment of my Chefmate bc 87/h mini refrigerator and I can't find parts anywhere. Help!!!
tnx 4 using fixya,
drcool
Sep 13, 2008 | Refrigerators
Refrigerator
Jan 03, 2008 | Refrigerators
LG GC-051SS Compact Refrigerator Logo
416 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
