Question about Motorola Mobility Rival A455 Cell Phone
The screen works but it is just really dim what do i do to make it back to normal?
  • 437 Answers
Hi the first thing you can tdo is pop the battery out. The second thing is goin the display settings is see if the automatic dimess is on . Turn offf the automatic dimess. MAKE IT brighter to what you desire. If this doesn't work call 611 form your cell and have them send you a replacement. Use the backup assistance on your phone. hope this help
Posted on Nov 08, 2010
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
JVC HD52Z575 hdtv - replace lamp but screen still dim
A ballast is possible but was the Lamp you replaced JVC or a generic lamp from the internet?
Mar 12, 2012 | Televison & Video
I dropped my iphone 3g on the ground at about 4 feet. and the screen is super dim. and i can cant see the words. but the phone is still working. the screen is just really dim
Yopu got a problem with your crystal IC for the LCD, it probably mis-aligned from solderd, bring it to a technician andhave them Re-heat the crystal IC at the back of the LCD screen
Nov 09, 2009 | Apple iPhone 3G Premium Polycarbonate Red...
My ipod screen is really dim
Follow the 2 steps I follow all the time, retry, and restore your ipod. My itouch's screen was also really dim but when i restored it, it turned bright.
Mar 17, 2009 | Apple Audio Players & Recorders
Delll axim x30 screen remains dimmed even though fully charged
ok , you have checked the brightness settings, check battery power settings as well. you may have to do a hard reset so back up your info. If doing a hard reset, pull the battery and charge it on its own if you have a cradle. Hope this works for you
Feb 28, 2009 | Dell Axim X30 Pocket PC
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Lgvx9400 screen turns black
Well I have ahd the same problem as you guys have (screen turns black, the whole charging issue, etc.). A short term solution for this and percautions for the future for this problem would be this:
Try this (and this worked for me): Tap gently and hard with your index and middle finger on the screen, while its off and on (experiment with it). Though this might not be garunteed to work but its a shot and it worked for me.
Also charging it wont be that bad of an idea after tapping it while off, cause the screen might come back to normal (it will show you that the battery is charging, no diming)
once when you get your screen back to normal, try jus to be carefull and get a case if possible to protect the screen. cause I think for this phone the screen is really sensitive after a while, so jus dont have your phone on you when your doing something active. get a case (best solution really).
Jul 29, 2008 | LG VX9400 Cellular Phone
Sony KP-51hw40 goes dim and turn off
Unless you know how to solder and where to solder you need to take your set to a repair shop ,however if you do know both of these things to do solder around Flyback Transfomer pins.
ThankYou for using FixYa. Have a nive day.
Feb 07, 2008 | Televison & Video
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Motorola Mobility Rival A455  Cell Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
