I am trying to use a new Logitech USB desktop microphone with my Mac OS X version 10.4.11. It seems to be working beecause the screen icon fluctuates when I speak, but I cannot find a way to record anything, or hear my voice.
  • 5 more comments
  • alnaso Jun 15, 2008
    I have already done everything you have described. Now----how do I get the microphone to record on my hard drive or on a CD? I do not hear my voice, nor can I find a record sound button anywhere.
    That is just it. I cannot find a recording program anywhere.
    I cannot find any of the great ones a mac comes with. Where are they and what are they called, so that I can find them?
    Yes, but no record button shows on the Windows Media Player screen
  • alnaso Jun 16, 2008
    I just downloaded audacity and it says it is not supported on my system. Mine is mac version OSX 10.4.11
    when I go to File, there is no "New.'
    I have downloaded the Sound Recorder and have been able to use the record button, but when I record, I get nothing.
    Guru:
  • 859 Answers
Your problem is easy to fix. You have to have a recording program open to record to a file. You can find this in your main menus. Your microphone is working fine from what you wrote. Once you save your recording you can email it, etc.
Regards,
Worldvet
Posted on Jun 15, 2008
  • 2 more comments
  • Glenn Rogers
    Glenn Rogers Jun 15, 2008
    Do you have a media player like quick time?
  • Glenn Rogers
    Glenn Rogers Jun 16, 2008
    From within WMP choose File, New and then you can record.
  • Glenn Rogers
    I'm afraid Apple in its wisdom did not preload any recording features on your machine and usually the programs that will let you record on an Apple will cost you money.
    You will want to find software that allows you to record on your Apple by doing a search or going to the Apple Store.
    You can choose not to accept any of these solutions since we can't solve your problem and you won't have wasted any money or you can choose one amongst the many and be done with this.
    If you feel more comfortable visit your local authorized Apple dealer for a real solution.
    Regards again,
    Worldvet
  • Glenn Rogers
    I hate USB mics for just this reason.
    Sergeant:
  • 243 Answers
1. Plug the microphone’s USB connector into the USB port on the side of the
keyboard (NOTE: Make sure that the keyboard is plugged into USB port 1).
2. You must specify the input device (microphone) that your computer will use:
Go to the Apple Icon in the upper left corner and select “System Preferences…”
from the pull-down menu.
3. Under the Hardware section select the “Sound” icon.
4. At the Input tab you’ll see a “Choose a device for sound input” field. If the
microphone has been properly plugged in you’ll see its name “AK5370” in the
name list along with “Line In”. Select the “AK5370” option to enable the USB
microphone.
5. If not already on, push the oval button on the microphone. When enabled, the
button will be in the up position and lit with a green light. Push the button in
when you want to disable the mic.
6. At the Input tab under “Settings for selected device:” you can adjust the
microphone Input volume and test the volume level by speaking into the
microphone and watching the blue bar gage. Adjust the levels to your desired
setting. The microphone is now ready for use.
here you go hope this helps. Thanks Nathan 06:38:28 cst
  • 20 more comments
  • Nathan Ayers
    Nathan Ayers Jun 15, 2008
    i used my microphone as an example. but yours will be listed under its own device name.
  • Nathan Ayers
    if that solution doesnt help you out please let me know so i can further assist you.
    Thanks,
    Nathan
  • Nathan Ayers
    1. Go into System Preferences,
    2. Open Sound,
    3. Select Input
    4. Select Mic Input
    this is in short all you need to do on a mac in the current OS x
    it should automatically disable the onboard microphone if selected. after that point you may need to configure it on the program you are trying to use.
    Thanks,
    Nate
  • Nathan Ayers
    if you need a program to record with beyond the great ones a mac comes with. I suggest my favorite one Audacity so i hope you enjoy.
  • Nathan Ayers
    just use audacity to record its simple and if youve done everything as youve described. then you just need a program. with Audacity theres a record button and it uses the default recording device this should be all you need and good luck.
  • Nathan Ayers
    install audacity and if you need help figuring out audacity let me know. I will run you through everything you need to get recording. Glad to help, Nate
  • Nathan Ayers
    your mac didnt come with garage band or anything like that?
    if not Audacity is the way to Go. its protools but free.
  • Nathan Ayers
    as i am on a mac right now. Mine is located on the default drive under garage band. but you might not have it at this point. the next best recording tool for mac's is as ive said is audacity. then install audacity and hit has a simple interface that you can open a new project and just hit record. and your logitech microphone should be working great. then you can save it to any file youd like and be set.
  • Nathan Ayers
    you dont want to use windows media player on your macintosh.
    you might not have the recording utility. if you have a standard osx install.
    Click here to download audacity.
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    really i have it on my computer at this moment. is that the latest OSx?
  • Nathan Ayers
    then you can use an official program called 2 programs
    first being official sound recorder which is the utility mine came with
    click here for sound recorder 2.1
    or another one that is free called audio recorder 3.2
    click here for audio recorder 3.2
    i tried both downloads and installed successfully let me know how it goes.
  • Nathan Ayers
    and on the audacity note did you try the beta? that might be why mine worked? just a thought cause its such a great free program.
    thanks,
    Nate
  • Nathan Ayers
    cause the beta 1.3.5 version is suppose to support osx 10.4 and 10.5 now
  • Nathan Ayers
    there isnt one in mine either on osx 10.5 but then again ive never used WMP to record either.
  • Nathan Ayers
    here this is the audacity you need to use click all this and its the exact download.
    i forgot where it says
    "Audacity 1.3.5 requires Mac OS X 10.4 or later. Users on OS X 10.3 who wish to use a Beta version of Audacity should download the previous version."
  • Nathan Ayers
    actually contrary to what he said there is lots of free softwares to record on a mac. i just failed to give you the correct download to begin with. I think after you try them out. you will find one to suit your needs perfectly.
  • Nathan Ayers
    id like to try and save you money before having to run to the apple store and they charge you 50 dollars for sound recorder which is free online :).
    i think there is enough here now for you to be able to record. Glad to help
    -Nate
  • Nathan Ayers
    Can you tell me if your speakers are working correctly. might be a dumb question just need to eliminate it.
  • Nathan Ayers
    because if you downloaded sound recorder and the wave bars are moving as you talk then its creating audio. and i need to ensure that your speakers are not hooked up or are disabled in OSX. as that could be the problem as if you are seeing the waveform it means its getting the signal.
  • Nathan Ayers
    play some mp3's or something and let me know if you hear them.
  • Nathan Ayers
    let me know when you are able to try that out. if thats isnt the problem and your speakers are working. Can you try to use the internal mic for me. Tell me if it works when you record something then play it back.
  • Nathan Ayers
    I take it you got everything working by the fixya and i just want you to know that i was glad to be of assistance and if you ever have problems on your mac like this again feel free to contact me as im sure i will be able to assist you. Thanks, Nate
    and Thank You for using FixYa
    Scholar:
  • 198 Answers
Please keep the microphone a bit away from ur screen... its because, powerful electro magnets will be ther in the microphone... wen u keep it very close to the screen, the waves cause the fluctuation in the screen which wil shorten the life off ur screen
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
I accidentally threw my safari icon in the trash and now i can,t get it back
Unfortunately, it wasn't just an icon -- it was your entire Safari application.
You can copy the Safari application from another Mac running the exact same version of the Mac OS as your machine, using a CD or USB stick.
Mar 14, 2010 | Apple iMac G4 Desktop
I have just bought this webcam for my mac but seems unable to set up
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 20, 2009 | Creative Labs Live! Cam Notebook Pro...
I have an OS 10.5 Mac and a Logitech desktop microphone. I want to record and play back voice. What software do I need?
Mac come with builtin Sound Recording Service. You need to follow these steps to record sound through your microphone.
  1. Click the Apple menu and select Control Panels; select Monitors & Sound
  2. Click the Sound icon.
  3. Under Sound Monitoring Source, select one of the seven input sources (where the sound will come from): Built-in Mic, External Mic, Sound In, Expansion Bay, CD, Zoomed Video, Internal Modem, RCA In, DAV Analog In, or PC Card. Some systems may not have all choices.
  4. Choose Sound Output Quality: 11.025, 22.050 or 44.100 KHz. Some systems may not have all choices.
  5. Click the Apple menu and select Simple Sound.
  6. Click the File menu and select New. You're presented with a window set up like the controls on a tape recorder.
  7. Click the Record button and start your sound (either speaking or singing into a microphone, or playing your CD, or whatever).
  8. Click the Stop button when you're finished. You can click Play to check what you recorded.
  9. Click Save. You're presented with a Save dialog box in which you can name the sound file and place it in whatever folder you like.
You are done. If SimpleSound isn't in the Apple menu, search for it with Sherlock (press Command-F). To play the new sound file later, just double-click its icon to open SimpleSound.
For further help please visit http://www.ehow.com/how_6538_record-sound-mac.html
Please do rate my solution.
Regards, Rashid.
Oct 28, 2009 | Logitech USB Desktop Microphone
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
Jun 19, 2009 | Apple iMac G5 Power Supply 661-3351
Logitech gamepad
i checked with logitech and it seems this is a common problem the controller and it is suppose to work with the mac with no drivers however it seems the design flaw is that it does not work with alot of mac games.
my suggestion get your money back or sell it on ebay and try to get a controller that works with mac
Apr 27, 2009 | Computers & Internet
Can't install a logitec quickcam E 2500 on my mac
The Quick Cam line ever had drivers for Mac OS versions. See the specifications here: http://support.logitech.com/en_us/product/quickcam-connect-product/specs . The E2500 works with Windows XP and Vista. You may be able to use the camera in Boot Camp running one of these versions of Windows. The Quick Cam E2500 doesn't work with Windows 7 and newer Windows OS versions.
The Logitech Webcams, including the C525 and the C920, will work with a Mac directly.
I wish that I had better news for you.
Aug 16, 2017 | Logitech QuickCam Chat Personal Web Camera
My Logitech Microphone needs software.
try here
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en?selectedcrid=408&selectedcid=221#
Sep 06, 2008 | Logitech USB Desktop Consumer Microphone
I have a MAC MINI AND MY USB MIC IS NOT WORKING ON IT.
This product uses native driver support on a Mac. No Logitech Mac Software is available or required.
It should work instantly check your sound settings the mic might be on mute or your useing wrong input on your program.
Jan 14, 2008 | Logitech USB Desktop Consumer Microphone
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
