Question about Gaggia Classic Espresso Machine
Water leaks around groop - Gaggia Classic Espresso Machine
  • Gaggia Master
  • 1,711 Answers
There is a gasket "o" ring around the group where the filter sits. This it might be dirty or tear out. Try to clean with brush and if you still have leak then replace it. Visit Partsguru.com for the brush and other parts
Posted on Dec 01, 2010
Water loss on a 2007 jeep wrangler no visible water spotted
No visible leaks--- BUT--- you see some coolant
around the intake !!!!?
Your going to have to realize that the water pump
can leak,the intake may leak & a head gasket or
radiator,hoses, etc can leak
We can not do the checking & guessing for you
Aug 12, 2014 | 2007 Jeep Wrangler Unlimited Rubicon 2...
What is a constellation star
Any star that is part of what makes up a constellation.
A constellation is a groop of starts thatmake up a figure (like the big and little dipper(s))
Jun 12, 2014 | Cloud b Twilight Constellation Night Light
I can't send groop emails on new yohoo page not sure how to do it please help
Hi ,
Yahoo! Groups - Wikipedia, the free encyclopedia Not helpful? You can block en.wikipedia.org results when you're signed in to search.en.wikipedia.org - You +1'd this publicly. Undo1.6.1 Groups Updates Email; 1.6.2 Yahoo Groups remodel; 1.6.3 Group Deletion .... Groups blog stated that Yahoo was working to fix the problem
gorbesia
Oct 20, 2011 | Yahoo Mail
Water leaks onto pass side floor only when it rains. the area under yhe cowel is clean and water runs by the wheel well like it should. leaks when car isnt running
First I would check and see if its leaking for the front window.take a water hose and spray water around the seal of the window and see if it leaks. If it don't then I would take do the same test around door seal and the passanger side window.
May 26, 2011 | Dodge Stratus Cars & Trucks
My 1999 Alero must have a leak somewhere because the thermostat gauge rises every few days. I put coolant in it at least 1 a week. I had a new water pump and thermostat put on it, but it is still...
CHECK AROUND WATER PUMP AREA.AND THERMOSTAT HOUSING FOR LEAKS.THE MECHANIC WHO PUT THE WATER PUMP ON MAY FORGOT TO PUT SEALANT ON BOTH SIDES OF THE WATER PUMP GASKET CAUSING LEAKS.LOOK AROUND THERMOSTAT HOUSING FOR LEAKING.IF THERMOSTAT SEAL WAS DAMAGE DURING INSTALLATION IT WILL CAUSE LEAKING.IF ALL LOOKS GOOD CHECK FOR COOLANT LEAKS AROUND RADIATOR .CHECK RADIATOR TOP AND BOTTOM HOSES FOR LEAKS AND CHECK HEATER PIPES AND HEATER CORES HOSES FOR LEAKS.IF ALL HOSES GOOD.CHECK FOR LEAKING CORE PLUGS.
Sep 26, 2010 | 1999 Oldsmobile Alero
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Water on flour of water heater
If your water tank is leaking, is it dripping from above or actually leaking thru the bottom?. Can you find the source? Feel around and try to find wet spots above and around it. If it's not leaking from the water pipes or T&P valve, it's your tank leaking. You'd be wise to have it checked out in the morning, before it gets worse. Hopefully your catch pan has a pipe attached to divert water to the outside or to a sump pump or floor drain. Water heaters do sweat, but you can tell the difference if it continues to leak for several hours.
May 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
STR-DB840 no sound in speakers
There are 4 blue relays in the unit that has solder points that will crack over time.
It´s fairly "easy" to re-solder them and viola, it´s OK again.
open the cover (unscrew and take of the hood) and locate the 4 blue relays.0cddb82.jpg Unscrew and remove the bottom service plate and locate the soldering points for the 4 relays.c0f1d35.jpg
Each relay has 6 solderings, 4 in one "groop" and 2 in one "groop" look especially at the "2-groop" these are the ones most likely to crack over time ( for me 12 years or so).3436d08.jpge6f7344.jpg
Re- solder. Best of luck //Ronnie Stockholm
Jan 27, 2009 | Sony STR-DB840 Receiver
Gaggia Classic Espresso Machine Logo
338 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
