The connection works but we cannot get to the explorer. There seems to be a setting to adjust and I don't know how to figure it out.
    Champion:
  • 214 Answers
For this try the following.
First of all, make sure that the connection you have got is internet connection or LAN connection. If its LAN connection you have to make sure that one of the networked computer should be dialled or connected.
If its internet connection, then goto Control Pannel, double click Network connections
Find out your connection from the list there.
Right click the connection and select properties
In the property dailog box, click on the Security Tab and there
in the security options click on Typical and in the 'Validate my identity as follows' combo box select 'Select unsecured password' Finally click OK and try to explore.
Also from the control pannel double click the Internet Options and in the Internet Options dialog box select 'Connections' Tab
and make sure that there appears your dial-up connection name in the Dial-up and Virtual Private Network Settings.
Make it the default connection
If its not there you will have to a Add a dial-up connection
Hope this will solve your problem
by Rabby
Posted on Jun 16, 2008
  • Rabby V V
    Rabby V V Jun 16, 2008
    no comments at this point
Sony STR-DE697 Center speaker not working. All connections correct. Seems to need to be "enabled" can't figure out how to
Here is a link to the configuration process.
http://pdf.crse.com/manuals/4252272111.pdf
Everything you need to set up your speakers is there. Hope this helps! Don.
Dec 10, 2013 | Audio Players & Recorders
I do not understand about torque on my new makita 18v lithium-ion battery drill. When I use it through drywall then into wood or straight wood into wood it seems to stall when I am almost done. Is this to...
Hi Kathy,
Welcome to fixya!
You adjust the torque by increasing the setting on the dial behind the chuck. It will feel to you as if you increased the power when you drill.
Don't set it higher than you need it. Just increase the setting until you're happy with the way it's working.
Good luck
Please place a vote and keep me working here...
Thanks,
Handie Andie
Aug 14, 2011 | Makita Garden
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
WBR2310 messes up my Wireless card...
reset yoru modem and wireless then after that go to windows explorer and type in the default ip which is 192.168.0.1 then it should be able to connect to your router an you setup everything from there, it worked for me.
Jan 25, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Yahoo Browser connects to internet, but Explorer&AVG update wont
Yahoo Connects but IE and AVG wont
1. Try opening AVG and adjusting the connection settings.
2. Go to Start/ Network connections/ Local area connection/ General tab/ Scroll down to TCP/IP/ highlight it and click properties. Make sure "obtain IP address automatically" is checked. Under the advanced setting there, DHCP should be enabled.
3. Verify setting in Internet Explorer under: Tools/Options/ Connections/ Lan Settings/ select "automatically detect settings"
You might also check your AVG program for a firewall conflict or block there.
Let me know if this helps
Dec 30, 2008 | Computers & Internet
I am a new Home Max customer and I have followed the instructions to connect my Live box to my PC. My laptop is working nicely wirelessly but my PC is not. The problem is that Internet Explorer keeps...
Reinstall the Internet Explorer, that will help.
U can reinstall Internet Explorer by clicking on start, control panel, add/remove programs, add/remove windows components, remove a checkmark next to Internet Explorer.
Then restart the computer.
Again go to start, control panel, add/remove programs, add/remove windows components, put a checkmark next to Internet Explorer.
Then apply, ok and again restart the computer.
Try to connect to internet and then check.
It will not close again.
Its possible that something might have been downloaded accidently and that is interfering with the internet.
It should work.
Otherwise, go to start, run, msconfig, startup, disable all, apply, ok and he restart the computer.
It will block some programs that may interfere with ur Wireless Internet Access.
It will work.
May 22, 2008 | Computers & Internet
Everything reads ok-power-connection excellent-Still keeps coming up as not connected,can you help
Have you tried to disable your firewall? Also open internet explorer, select tools, internet options, connections, LAN Settings, Click Automaticly detect settings, select ok/close, restart internet explorer. let me know if that works.
Oct 27, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Menu (SCREEN) #4 Adjusting projection is gone
you have a convergence problem and this can only be serviced by a tech with the know how to service the rca projections sets as there are many alignments in this set and some are manual driven but mosrt are on screen driven. You need the know how to get into the service mode. Sorry my friend but my recomendations would be to send this set out for service.
Jun 08, 2006 | RCA P56812BL 56" Rear Projection...
Wi-Fi
You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success. The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
Sep 08, 2005 | Toshiba e740 Pocket PC
Computers & Internet Logo
428 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
