Question about Motorola Mobility Droid X
Signal strength fades in and out even when it shouldnt. Calls are constantly being dropped. Please help. I really love every thing else about my Droid. I am apprehensive of terminating my Alltel account even though I have met all contract terms and conditions, due to the fact that my Droid is so unreliable...
  • G Saldana Nov 08, 2010
    Is it still in warranty? Have you spoken with alltell?
  • 437 Answers
Hi first thing you need to do is take the back out of your phone. Next do a *228 on your phone. option #2 . Make sure the battery is put back in your phone.Go into the settings on your droid make sure that the wifi is not check on on the phone. IT shouldn't be check green on your phone. Next go on to your gmail get the gmail address and the password for your phone. Because you may need to do a hard reset on the phone. Go into setting and the privacy section has the restore to factory reset.Also make sure that your phone is not in airplace mode this can happen because of the way the phone shutts down.
mode.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Posted on Nov 08, 2010
Rumor reflex signal fades and drops calls too often. Help?
Two possible problems: hardware or carrier. So a few questions:
- Does this happen everywhere, or only certain places?
- Does this happen when the phone is in a strong signal area, moderate strength signal area, or weak signal area?
It is possible that the radio simply isn't powerful or intelligent enough to hang on to a weak signal, or it is possible that you are in a very weak signal area. My first route would be to contact the carrier and ask for a signal check in the area where it happens most often. If the carrier confirms that the signal is good, you either have a defective handset, or a simply poor one.
Dec 11, 2013 | Cell Phones
My calling are not connecting. They drop after the first ring. Please help
if you are using Wireless then please check your wireless signal strength !
if its low then eventually your calls will drop
Aug 04, 2011 | Skype IM
I have really poor signal most of the time, sometimes it's "emergency calls only" for no apparent reason, sometimes it says the GPRS is detached, sometimes there's just no bars even though i'm...
Are you using an old SIM card? Sometimes a worn out SIM card won't make a solid connection with the metal contacts, resulting in a drop in signal strength.
You might want to look into getting a new SIM from your carrier, and see if that helps.
Otherwise, I am guessing it is a hardware problem with the phone itself.
Mar 01, 2011 | Sony Ericsson P1i
Cannot use phone function on x10 (e.g calling, sending text msgs), other xperia functions, internet ok. Sim card detected and can load contacts but cannot call. dont understand why this is happening.help...
i have exactly the same problem it is happening to me as it occurred 4 days ago just happened when trying to call it just say call ended and cannot receive and send calls or texts either.
signal strength is full i have hard reseted it and done almost everything my x10 is on orange and i cannot thing of a solution for the problem i go it online and cannot get return it to anyone when i revived it, it was fine its just happend i hope there is a solution because i love the phone.
Apr 25, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Nokia 1600 is dead how to repair it
If your phone appears to have problems with power, the problem may be with the phone, the battery, or the charger.
  • The first thing to try is to connect the phone to its charger. Connect the charger to a power source, wait for a few moments, and then try to turn the phone on.
If the phone still won't power on, please perform the following checks:
  • Fully charge the battery according to the instructions presented in the user guide.
  • Remove and re-insert the battery according to the instructions presented in the user guide.
  • Check that you are using a Nokia battery and charger compatible with your phone model. You can check compatibility from the Battery Compatibility Chart and Charger Compatibility Chart.
  • If you have access to another battery and charger of the same type as yours, try substituting them to determine if the issue is with the phone, the battery, or the charger.
If you are unable to test your phone or it still won't power on, please bring it to the nearest Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone is always low on power
If your phone appears to have problems retaining power, the problem may be with the phone, the battery, or the charger.
  • Check that you are using an original Nokia battery and charger compatible with your phone model from the Battery Compatibility Chart and Charger Compatibility Chart. If your battery features a hologram label, you can authenticate that the battery is an original Nokia product with our Check Your Battery service.
  • Even high-quality batteries like Nokia's will eventually lose power retention capacity. If it is time to replace your battery with a new one, be sure to purchase an original Nokia battery from an authorized Nokia dealer.
If you are unable to test your phone, charger, or battery or need further assistance, please bring them to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My calls break up/are dropped
Dropped calls or low sound quality during calls can result from low signal strength or momentary gaps in network coverage, either at your end or the other end of the connection.
In most cases, your operator or service provider is the best source of assistance with issues regarding signal strength.
  • Signal strength is indicated by the signal indicators at the left side of the phone's display, these indicators move up as the strength of the signal increases and down as the signal decreases.
  • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
If you continuously experience low signal strength in a certain area, it may be that network coverage is insufficient there. Your operator or service provider can provide you with more information on network coverage.
If you believe that the problem may be with your phone instead of the network, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't ring
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
If your phone still won't ring, please bring it to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't send/receive messages
Email, text messaging, and multimedia/picture messaging must be supported by your contract with your operator or service provider. In addition, your phone must support these features and have the correct settings.
  • Check the types of messaging supported by your phone model. You can find this information in the user guide. Look for the terms SMS for text messaging and MMS for multimedia (picture/audio) messaging.
  • Contact your operator or service provider to check that email, text messaging, and/or multimedia (picture) messaging are included in your service contract. Also verify that roaming is supported when you are not within your home network.
  • Install messaging settings for your phone. You can download settings for free from our Setting service.
If you are still unable to send or receive messages, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
I want to recycle my phone and accessories
Just drop of your old mobile phone and accessories at any Nokia Care point. Nokia will send the old products to closest Nokia approved recycling company. Mobile phone recycling leads to both material and energy recovery from old devices, and helps ensure the proper disposal of harmful substances.
Apr 24, 2009 | Nokia 1600 Cellular Phone
Wirless signal strength fades
it sound like to me that someone is logging on to your router set up your laptop with wep or wap with 128 bit enycription and let me know how that works
Mar 17, 2009 | Toshiba Satellite A105 Notebook
Fading Signal Strength
could be a worn rf modulator
this controls the radio frequencies.
If you are having trouble with dropping calls that last for a little longer than normal 1-2 mins then that would be my guess
Nov 08, 2007 | Nokia 3120 Cellular Phone
Used phone many problems
Contact your network provider. They can test the signal of the phone and also reset it to the network settings. Have you turned your phone off recently? Leaving a phone on continually will sometimes give you these errors. The network updates the software in your phone and if you do not turn it off once in a while the updates will not be applied.
Sep 18, 2007 | LG CU500 Cellular Phone
Motorola Mobility Droid X Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
