Question about TruTech KLV3112 10 in. LCD TV/DVD Combo
Do i need a converter box or attena for this tv??
  • TruTech Master
  • 8,457 Answers
U require a good antenna no need for a converter box,because this tv is digital tv.
Posted on Nov 08, 2010
Tv won't turn on
Check your cables, and power point and attena and fuse box
Nov 21, 2015 | Sharp Aquos Televison & Video
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
I am getting a NO SIGNAL as soon as I turn on the TV
Antenna may have to be re-aimed or replaced. Go to www.dtvanswers,com for details.
Jul 01, 2009 | Insignia IS-LCDTV32 32 in. Television
Do I need digital converter box?
if you have cable or satillite than you do not need a converte box unless you have basic cable where the cable wire plugs right into the back of the tv if so a converter box will be needed to viev all chanels
Dec 03, 2008 | Symphonic ST427FF TV
Sanyo DS31590 31'' TV DO I NEED CONVERTER BOX?
If you do not have cable or satellite YES you will need converter box anyone and everyone that uses antenna to watch tv needs converter Box.
Nov 21, 2008 | Sanyo DS31590 31" TV
Loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Tv attena
check attena connections if these are ok try retuning tele
Sep 20, 2007 | Panasonic CT-32SL14 32" TV
TruTech KLV3112 10 in. LCD TV/DVD Combo Logo
192 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
