Question about Texas Instruments TI-89 Calculator
Having problems calculating log and ln with TI-89 Titanium
  • kakima Nov 08, 2010
    Could you describe the problems? What keys are you pressing, and what results (if any) are you getting?
F(x)=5.2x+5 lg'3x2-2'
Posted on Jan 04, 2011
TI-89 "ln" function returning a "ln" answer
To convert a result from symbolic to numeric, press diamond ENTER. To have all results appear in numeric form, press MODE F2, use down-arrow to get to the "Exact/Approx" line, press right-arrow, down-arrow to "3:APPROXIMATE", press ENTER ENTER.
Feb 07, 2013 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
How do you enter the log base on the TI 89 Titanium?
If you want to take the log base b of x, enter it as log(x, b).
To get log, you can either type it in or press diamond 7.
Nov 23, 2010 | Texas Instruments TI-89 Calculator
Where is the log button on TI-89 titanium?
The natural log is marked LN, the 2ND function of the X key (just below HOME on the leftmost column of the keyboard).
The common log is not marked on the keyboard but can be accessed by pressing diamond 7. You can also access it via the CATALOG and/or spell it out.
Sep 20, 2010 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
How to find cubed root on a TI-89 calculator
To find the cubed root (or any root) of a number, use the root() function.
If you want the cubed root of 125, you would type:
root(125,3)
Mar 06, 2009 | Texas Instruments TI-86 Calculator
How I can get the log base 10 number in a TI 89
"♦" "7" will give you log base 10 for the texas instuments TI-89 Titanium
Feb 20, 2009 | Texas Instruments TI-89 Calculator
Log & reciprocal functions
There is no log (base 10) button on a TI-89. It's buried in the CATALOG as log(. As a shortcut, you can do ln(#)/ln(base), where # and base are replaced with what you want. For the inverse of a log, do the base raised to the part on the other side of the equals sign. So, log(x) = 2 would become 10^2 = x.
Jul 16, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
165 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
