Question about Frigidaire Electric Dryer
DRYER MODEL AEQ7000ES1 keeps getting "error 68" message and shuts off. Some days it works perfectly, but most it gets this error and can not work at all.
    President:
  • 3,074 Answers
E68 means a button is stuck on the control board, you can lightly press all buttons and see if that clears the problem. Next slam the door shut as it may be the sensor door latch, then unplug the dryer as it maybe lint built up on the lint trap: remove your lint filter.remove the waffled plastic that covers the lint filter slot. , its inside the dryer, and there's two screws holding it in. Be careful, because there's two wires connected to the metal strip on the bottom edge of it. That metal strip is a sensor. Don't drop the screws into the lint filter slot. you might find that a lot of lint has built up around the contacts for those two wires. Carefully clean all the lint and if you have an attachment for you vacuum you may want to use it just be careful and plug back in , and reinstall. Might want to check the vent tube since we are cleaning as it may be restricted. unplug dryer and the last thing is to take the back off and see if the control board itself is damaged or dirty, if it is dusty/dirty with a brush lightly brush it off. If none of the above worked then I would call the company at 1-800- 444-4944. Good Luck Tim
Posted on Nov 08, 2010
I HAVE A EURODESIGN DRYER BOUGHT IN '03 I now have error 68 message and dryer stops - anybody know what this means - cant find it in the manual. thanks
It means it has a stuck button.
I'm taking it that it's a Fridgidaire.
on the door you should have a model number that looks like this
AEQ6700FS .
http://www.searspartsdirect.com/dryer-repair/error-codes/frigidaire-dryer-error-codes.html
Once you find this and you need a manual goto
Browse Products
Apr 17, 2015 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
No heat to the dryer. Everything else seems to function properly. Frigidaire AEQ7000ES1. Receiving E9 Error code.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101]][
Jul 18, 2011 | Frigidaire Electric Dryer
I need help with my ps2, its about 4 years old, The bulky model. up until a few days ago, it worked perfectly. yesterday it was a bit glitchy, but a few resets fixed it. Today i wanted to play it, so i...
clean the laser using a lazer disc cleaner not only does the disck get dirty but the lazer too when its too dirty it wont read the disc -- disc error
heres a piture of one you get them from electronics shops
Dec 31, 2010 | Sony PlayStation 2 (PS2) Console
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
Samsung HT-TX52 keeps shutting off.
I've had the Samsung HT-TX52 for almost a year now, and just recently, after about 10 mintues it keeps shutting off. Its almost like new and hardly used, why is it doing this?There is no error message, it just shuts off. I've tried unplugging it for a day, taking out all my wires and reconnecting them perfectly, and it still does this robert
Jun 13, 2009 | Samsung HT-TX72 Theater System
ERROR MESSAGE E 68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Apr 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Error 68
Hi!
Also visit this link--
Xbox Error 68
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 19, 2009 | Microsoft Xbox 360 Console
Frigidaire  Electric Dryer Logo
355 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
