Question about Garmin nuvi 765T GPS Receiver
I have 765T Garmin. It won't charge from cigarette lighter. REturned first Garmin to company, got a "newly refurbished" unit, so it's different. Still won't charge from car. Cable lights up, replaced fuse, still no go. Tried in two different cradles. Still won't run from car cigarette lighter. So it's not the Garmin, doesn't appear to be the cable, and doesn't seem to be the cradle. Ideas?
    President:
  • 1,111 Answers
If its an oem garmin charger and the green light is on and still wont charge, then the problem is most likely the power port on the back of your garmin...if its not the factory charger, get one for a garmin..that should solve your problem...if not, let me know
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Nov 08, 2010
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
I have recently purchased the Garmin nuvi 765T and I have charged it and waited to use in the car but after a few seconds of turning it on, it turns itself off after showing the "Garmin" company...
Try to soft reset it by holding the power button for at least 20 seconds till it restarts.
If that doesn't help - try a master reset to factory defaults by holding the lower right corner during startup for at least 20 seconds. This will erase all user data and starts the Garmin in factory default.
If it restart I suggest updating the software to the latest version on Garmin.com
Jul 04, 2011 | Garmin nuvi 765T GPS Receiver
When I plug my Garmin Nuvi 765T into my car charger, it does not charge. Has the cord gone bad? Can I charge my Garmin through my computer?
The fuse may have blown in the charger. THe fuse is in the plug that goes into the cigarette lighter socket. Unscrew the ring near the tip of the socket being careful not to lose the tip. The socket comes apart when you remove the ring. Replace the fuse and it should be ok.
You can charge the satnav from your computer but it will take around 8 hours, twice as long as the car charger. Just connect it to your computer and turn both on to charge it.
Jun 16, 2011 | Garmin GPS
I have a garmin nuvi 765 and the screen does not come on at all. it worked fine before this. I dont use it a whole lot but i miss it...i tried plugging the unit in different vehicles, thinking that...
Did you get this working? if not, try connecting to your computer's USB port over night and turn on again. Install in the cradle in the car - if it goes out or none of the traffic receiver's LEDs do not light, check / replace the fuse in the tip of the power plug or the cigarette lighter fuse in the car's fuse panel.
If you need more help, leave a comment.
Jun 07, 2011 | Garmin NUVI 765T 4.4 in. GPS Receiver
Can my newly refurbished Garmin Nuvi 1200 GPS be charged in the car while the car is off?
Depends on the car. Most cars turn off the power to the cigarette lighter socket when the car is off.
May 27, 2011 | GPS
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
My Nuvi255 will only work on external power (cigarette lighter) almost like there is no internal battery installed
Have you tried charging this through other sources such as a usb or ac charger (please ensure the unit is off when attached to power to enter charge mode) as it may be the cable itself faulty, if it still doesn;t hold charge then the unit is faulty and should be returned to your local store
Oct 15, 2009 | Garmin Nuvi 255 GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 765T GPS Receiver Logo
1,120 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
