Question about Sterling Audio ST51 Microphone
I have a Sterling st51 mic that is connected to an m-audio mobilepre usb with an xlr cable which i am using to record onto pro-tools. The problem is that when i try to record my voice, even with phantom power on, it doesnt read it. i've tried using different mics and they work so I dont know what the problem is. Help!
SOURCE: a buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Posted on Aug 06, 2008
SOURCE: Rode NT2 got Phantom!
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Posted on Feb 15, 2009
  • 12 Answers
SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
Posted on Jul 29, 2009
SOURCE: need the wiring schematic from headset mic to vt2l belt pack mini
mini xlr
1 gnd
2 signal
3 +vcc
connect r 1k betwenn 2/3
Posted on Apr 26, 2010
  • 5 Answers
SOURCE: im not sure if its
First, Make sure you are speaking into the front of the microphone. there should be a logo or brand name at the front to show you. because of the cardioid pattern, sounds behind the mic are not picked up; good if the sound you want to isolate is at the front, not so good if it's at the back. Second, make sure the gain on the fast track is turned up. And third, try using a different program. It's unlikely to be the problem, but if it is, it's an easy fix.
Posted on Jan 20, 2011
How do I connect my CAD GXL2200 mic to my apple laptop?
You need a USB interface such as an M-Audio M-Track and a standard XLR male to female audio cable.
You use the cable to connect the microphone to the interface using the XLR cable, then you plug the USB cable on the interface to a USB port on your laptop. Finally, you go to System Preferences - Sound - Input and select the USB interface as the input source.
Depending on the software you you use for recording sound (I use Sound Studio from Felt Tip Software) you may need to go into the Preferences for the program and select the USB interface.
Dec 25, 2013 | CAD Microphones GXL2200 Professional...
I just bought the GXL2200 CAD microphone without the cabels,(thought they would've came with), what kind of cable do i need?
As with most microphones, these mics use XLR cables. You can get them online or in a music store in many different lengths. What you need is XLR male to XLR female, though most of the consumer-level stores will probably just call them "mic cables." Note that the thing you're plugging into will need to have an XLR input, and will need to provide phantom power in order for that mic to work.
Nov 09, 2013 | CAD Microphones GXL2200 Professional...
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
Im not sure if its a mic problem or an interface(m-audio fast track) or even if its the program im using (adobe audition 1.5) but when i record using the sterling ST51 it sounds like im about two miles...
Jan 15, 2011 | Sterling Audio ST51 Microphone
Can you plug a sterling audio st55 mic into a computer for recording?
In short, no. This PROFESSIONAL microphone requires +48v pahntom power which is privded by a mixing console. In order to connect to the computer, purchase a small mixer with Phantom power capabilities, a balanced xlr cable (male to female) for microphone connection to mixer, Out putleads from mixer to 3.5mm stereo jack to go from mixer to LINE IN on you computer.
I would also recomend a microphone stand, a vibration cradle and pop shield.
Jan 07, 2011 | Sterling Audio ST55 Professional...
My st51 is only recordin to one side of the audio track...how do i fix this
either one of your mics has burned out or more commonly the cable to one side either at the mic or plug has come off check the conections
Dec 06, 2010 | Sterling Audio ST51 Microphone
I have a mic Behringer C1u and would use it with an M-Audio fast track usb interface. How can I do it?
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Sep 10, 2010 | Behringer C1U Microphone
No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Jun 30, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Recording Device
Pcs needs drivers, and vista is far from being completely stable..
Disconnect the mobile pre...and go here:
http://www.m-audio.com/index.php?do=support&tab=driver&serie_ID=6&PID=8eb1a9920df341303f81bca7ff458be3&OS=45
then restart and connect.
Rock those beats, and keep me posted.
Dec 11, 2007 | M-Audio Mobilepre USB Bus-Powered Preamp...
Sterling Audio ST51 Microphone Logo
132 people viewed this question
Top Sterling Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sterling Audio Player and Recorder Expert? Answer questions, earn points and help others
