Question about Durabrand DU1301 TV
The DU1301 need a DTV converter or not?
Does the DU1301 need a DTV converter or not?
  • Durabrand Master
  • 520 Answers
Yes, if you use an antenna.
Posted on Jun 26, 2008
Do i need a converterbox for digital signal
Yes, you will need a converter box. This is an analog tuning set.
Mar 09, 2010 | Durabrand DU1301 TV
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DTV Conversion Question
Yes you can connect a DTV converter box in your van.
If the TV is DC powered you will need to buy a DC to AC inverter, like these http://www.dcacpowerinverters.com/12_volt_power_inverters.html because there are currently no dc dtv converters available.
If the tv is ac powered you will only need to connect the converter to the inverter the tv is connected to.
If you need more help or installation instructions let me know.
Please rate this solution.
Lone99star
Apr 03, 2009 | RCA R52WH73 Projection Television
DTV converter boxes
You need to look on the tv and see if has a digital turner symbol. If you can only pick up analog channels, you need a converter box.
Jan 22, 2009 | Sony FD Trinitron WEGA KV-36FS210 36" TV
Need to know if I need dtv converter for my Samsung combo tv
If you are using a cable TV or satellite service to get your TV content then you do not need a dtv converter.
You only need a dtv converter if you use an antenna to get your TV content and you do not have a digital TV with a internal digital tuner.
If you have the model # of your TV I can look that up for you if you are unsure.
Jan 12, 2009 | Televison & Video
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Durabrand DU1301
No. You will need a digital converter box for digital reception.
Jun 29, 2008 | Durabrand DU1301 TV
DTV box
I went to DTV.gov and got a coupon to buy a computer box for the change in Feb. 2009.
Feb 16, 2008 | Durabrand DU1301 TV
Durabrand DU1301
Try Emerson codes for the DU1301. 092 worked for me with my Brookstone remote
Dec 01, 2007 | Durabrand DU1301 TV
Durabrand DU1301 TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
