Question about Whirlpool LSB6000PQ Top Load Washer
Leaking warter from bottom small amount - Whirlpool LSB6000PQ Top Load Washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Whirlpool Expert
  • 154 Answers
EASY FIX, CHANGE WATER PUMP, ONLY 2 CLIPS HOLD IT ON, JUST LAY THE MACHINE ON ITS BACK AND THE PUMP IS RIGHT IN FRONT IT SHOULD BE WHITE OR GRAY
Posted on Nov 08, 2010
Leaking a small amount of thick liquid out the bottom
Take off the outer door cover sounds like the dispenser leaking
Jan 28, 2015 | Dishwashers
How fo i stop my fluids from running out my tail pipe
It would appear that the ice has caused considerable damage to the engine.. Have a compression test done to check for cracks and head gasket problems. have a coolant system pressure test done to check for leaks around the heads and block area including the heater core in the car.
Jan 12, 2014 | Cars & Trucks
Kenmore ultra wash dishwasher leaks from the bottom of the door edge
You electic water valve is sticking open, they get sand etc in there, and can not close, and will not shut the water input off. Do you have city water, or your own well water? Very common problem with well water, sand will clog the return of the water valve from shuttin off the water. Easy to check if you can shut the power off, and water off. dis-assemble the water inlet valve( first thing the input warter goes to)
Dec 19, 2012 | Kenmore Dishwashers
Water is coming from the bottom
Take off the panel at the bottem of dishwasher and find leak. If leaking from water supply connection try to tighten it first. If that does not work turn off water under sink and replace warter supply line. You can get a easy to handle braded line at you local hardware store. Replace other leaking parts at www.repairclinic.com.
Mar 24, 2011 | GE Profile PDW8480JSS Built-in Dishwasher
Spare wheel well keeps filling with water
The back side glass seal is leaking or wheel well seam leaking take the tire out drill a hole 3/8 or so
in the bottom so it drains when it rains or check it whith a warter hose
to find out where the warter is comming from
Mar 20, 2010 | 2002 Jeep Grand Cherokee
Oil leak out of a breather hose
a small amount of oil from the crankcase vent hose under hard acceleration is most likely normal.American bikes don't leak oil,they mark their spot!
Sep 28, 2009 | 2004 Triumph America
Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
May 12, 2009 | Hotpoint HSS25GFP Side by Side...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool LSB6000PQ Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
