Question about Ford 8n,9n,2n, Tractor Starter With Drive
New starter motor and bendix. will not engage with flyweel. starter motor just spins.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
Posted on Jun 07, 2011
Starter spins but why doesn't it engage?
There is a piece on the end of the starter called a bendix and it runs on a helix shaft. When you turn the key, the starter spins and the inertia force the bendix down the helix to engage the flywheel and spin the motor. yours is stuck. On old trick was to bang the starter housing with the shaft of a hammer to jolt the bendix into movement. Best way though is to remove the starter and clean and lubricate everything.
http://www.carpartkings.com/wp_blog/wp-content/uploads/2014/01/startermotor.jpg
If you have a pre-engaged starter, it looks like this and the solenoid isn't working.
http://garysautomotive.com/wp-content/uploads/2015/01/starter-motor.gif
Not sure if your tractor uses new or old technology, but you have both explanations?
Oct 03, 2015 | Briggs & Stratton Garden
Turn key get nothing jump starter and sylenoid just spins
i cant dope out that symptoms.
does it crank or not. be clear there.
no car starts (but my 6sp) if it dont crank.
on A/T cars cranking is a first thing. so does it.?
Solenoids do not spin, the stroke only , it a linear motion.
the Sol. moves the pinion and the main contactor switch only.
my guess is the Starter spins and the crank don\'t spin,
you hear the starter motor spin up, it sings. like bird.
that means the starter /solenoid are bad. (crude)
if the battery is good and or jumper starting off a running car.
It can just be a dirty starter pinion, clean it , repeat.
fixed many for this. i have.
battery cable lugs clean, and good. no green rust.
bad cable usually just make a loud THUNK sound. no spin.
Sep 02, 2014 | 2005 Jeep Wrangler X
Engine starter spins and will not start motor somethines.
Remove the engine cover to expose the starter motor (or take the starter off). Lubricate the starter bendix, its the gear atop the starter motor shaft, use Marvel Mystery oil and then work the bendix a bit and it should fix it. If the teeth on the bendix or flywheel are damaged obviously that is where the problem lies.
Jul 16, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a Poulan 18 HP 42" deck; battery would not charge so replaced it with new. Now starter gear will not engage with teeth on flywheel, sits just below engagement level and just spins. Suggestion
Most starters will have a bendix shaft, once the motor starts to rotate the gear follows the bendix thread up into the fly wheel ring gear, so there is either not enough charge in the battary, or the bendix on the starter motor is bad, or the gear itself is bad, or the battary is wired up the wrong way.
Feb 10, 2013 | Poulan 42 In Deck 165 HP 6 Speed Manual...
Strarter is not engaging
possible broken Bendix spring in starter motor..or starter is not getting enough power (check leads and connections)
Sep 23, 2012 | 2002 Kia Sportage
Starter motor whines but wont engage with engine on my rover P2
You will need a new starter rebuilt ect. to replace the one you currently have that is defective. you sound like you are spinning the starter motor but the starter bendix is no longer engaging the flexplate/flywheel on the engine.
Sep 10, 2012 | 1938 Rover P2
Starter motor not engaging
Hi without seeing (hearing) it sounds like the clutch in the bendix is faulty, as the solenoid will engage the bendix at the same time as connecting feed to the starter motor.
New starter required or a good strip down and rebuild on the solenoid and bendix.
What condition is the ring gear in by the way (Starter Motor removed). David
Dec 25, 2017 | 1988 Mitsubishi Pajero
Installed new starter, and it won't engage, just spins up. I inherated the car, it had a new engine and clutch installed in 2009, and it has been a on going problem. thanks db.
If it just spins when you turn the key, either the Bendix gear is not kicking out the starter gear, or the flywheel/flexplate hs broken or missing teeth. Was the old starter 'shimmed'? If so, did you put the same number of shims back in when you installed the new one? It is possible your starter, even though it is new, is not working properly-rebuilt units can be defective out of the box.
Jan 24, 2011 | 1992 Isuzu Rodeo
When i start the 95 tahoe, i hear a spinning noise. starter is not engaging the engine. it's a brand new starter.
Hello there:
The spinning that you are hearing is the bendix spinning there is a
engagement spring that forces the bendix to engage on the flywheel
If this spring is weak or broke the bendix cant engage furthermore if the teeth on the bendix are broke or chipped or the teeth on the fly wheel are chipped or broke -this will not allow the bendix to engage or start to turn the motor ok so i would have these things checked out ok?
I hope that this is very helpful for you best regards
michael
Nov 18, 2009 | 1995 Chevrolet Tahoe
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
640 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
