Question about Estes Rocket
I have a small Moon Mutt rocket I bought for my kids. It takes Estes fuels, 1/23-t something and I am certain I put it together properly but the fuels would not ignite. The detonator showed ready and light goes out when you press launch but no action at rocket. Am I doing something wrong ???
  • 1,498 Answers
Hi There,
This is essentially a solid fuel rocket.
The launch system consists of continuity check to insure the circuit exists once the the safety key is inserted, the the fire button which releases the full voltage/amperage.
If the light is coming on, that leaves power. If you aren't using a cart battery you need phototflash or similar type batteries that are capable of sending a quick burst of energy.
You need to test the igniters on their own away from the rocket until this is resolved. The igniters should be made to work consistently before trying with a live engine.
Power is where you need to focus.
Posted on Nov 08, 2010
78-6114 Telescope for my kids and I think everything is put together correctly. Lol. But when I try to view anything I shows nothing and yes I did remove the small cover at the end of the scope. Thanks!
Put the eyepiece with the largest number written on it into the telescope. Practice focusing on a distant object during the day time,. Also line-up the small finder scope with the main telescope.
The moon should be your first target at night.
You can download a free monthly star chart here:
www.skymaps.com
Read my TIPs on my profile page.
Jul 07, 2010 | Optics
Rocket 3 wont start. dials dead
Lift the tank. Underneath it you'll find a plastic connector block joining loads of wires together. Turn the ignition on and push this connector block together, or twist it around a bit. If the ignition sequence starts, it'll be because the wires in the connector block are corroded. Moving the block sometimes makes a temporary fix, but ultimately it'll happen again until the block or the wiring harness ideally, is replaced.
May 07, 2010 | 2007 Triumph Rocket III
We bought a Rokinon 500mm X 70mm Refractor Telescope for our father and he said it never worked properly. Now that he's passed, we cannot find the manual to ensure he put it together properly. In looking...
Yes you should be able to see the moon and several of the planets. Put the eyepiece with the largest number written on it into the telescope (put the diagonal in first and then put the eyepiece into the diagonal). DO NOT use the 2x barlow if you have one. Just too much magnification for a 70mm telescope.
You will not find a manual for that brand BUT Meade has manuals for all of their telescopes. Look under the header--- REFRACTOR-- on the page below for a manual similar to your telescope.
http://www.meade.com/manuals/index.html
Mar 02, 2010 | Optics
Washer overflows after taking it apart
You may have missed something when putting it together. Take it apart again then check and properly install the following:
  1. Water inlet valve. It may not be able to shut completely when the electricity has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
Aug 23, 2009 | Kenmore Washing Machines
Engines for the estes astrovision rocket
It's safe enough, but you better have a huge recovery area.
Apr 12, 2009 | Estes Rocket
Estes Astrovision Rocket Video Problems
You have to save it by clicking on the diskette icon. It will say it's saving as file type "jpg" but it actually strings them all together in an avi file. Then use media player or similar to view AVI.
Apr 11, 2009 | Estes Rocket
Lost part for rocket fishing rod
The same thing happened to my kids rods.
A friend suggested a product called Bobber Stopper.
It's basically a small bead and string. I found that the bead would not
reel back in, but if you just tie a piece of sting on the line big enough
so it does not fit through the bobber. It worked for me, so hopefully
this will work for you.
Mar 16, 2009 | Rocket Fishing Rod
Kenmore Sewing maching 158 15510: sewing mechanism
You put the hook (the half moon thing with a sharp point on it) in the machine by placing it opposite the little curved bar. Make sure it is seated properly on the ridge. The you take the race, the circular part with a small plate on the top and place that over the hook(the plate side will be facing up). It will only fit a certain way, it could have a slot that a notch fits into (that is usually how it goes). Then slide the arms over it and they will snap into place. Once done, turn the handwheel and make sure everything moves smoothly. If not, you'll need to start over as something isn't seated correctly. Then you can install the bobbin case as usual.
Feb 28, 2009 | Kenmore Sewing Machines
My estes Astrovision rocket will not seem to take pictures/videos
You have to make sure that you don't turn the power off from the time you record to the time you download onto the computer. If you turn it off, it automatically deletes what you recorded.
Jan 02, 2009 | Estes Rocket
Estes Rocket Logo
126 people viewed this question
Top Estes Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Estes Toy Expert? Answer questions, earn points and help others
