Question about Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range
Yesterday we hooked up gas and plugged in our BRAND NEW stove . There is no problem with the gas, it works both on top and in the stove. The problem is, the display screen is black/blank. When we press buttons, they beep, but we cannot see what we are doing. The manual is not helpful, it does not have a "what to do when you have a blank display screen" scenerio. We can get the oven to work, but have ZERO clue of any setting that we turn on because we can't see a bloody thing on the display. We have a 1-800 # for a tech, but won't be able to call til tomorrow. Any help would be greatly appreciated.
    Top Expert:
  • Jenn-Air Master
  • 52,099 Answers
Guess you wait until tomorrow .just as anyone else would
Posted on Apr 14, 2017
  • Anonymous Apr 14, 2017
    Wow! How helpful.
catriver
  • 878 Answers
SOURCE: Beeping noise - letters appear fc
Christina, FC means there is a communication error between your main power board and keyboard. There is a J2 harness that runs between them. You might try to reseat this harness. If that doesn't work the main board will have to be replaced. Catriver..post back.
Posted on Sep 14, 2006
  • 641 Answers
SOURCE: F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
Posted on Sep 06, 2007
SOURCE: Jenn Aire JGS9900BDS
it is probably the control board. Mine did this and they changed the control board.
Posted on Dec 13, 2008
  • 126 Answers
SOURCE: GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Posted on Jan 02, 2009
yecalam13
  • 41 Answers
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Posted on Jul 24, 2009
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KGST307&siteCd=WHRCOM&userType=Consumer
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
No gas to the oven, range works fine
This video shows where the lever is
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 06, 2010 | Ovens
Stove top works. no gas to oven
you may have a bad ignitor if unit doesnt have a standing pilot.....there may be a lever that needs flipped on the regulator. the regulator valve is where the gas line hooks to on the stove
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Kenmore gas stove Gas leak
I had this problem with my stove and had the regulator changed coming off the PROPANE tank.
Apr 04, 2017 | Kenmore Kitchen Ranges
Brand new gas stove. When oven is turned on there is a heavily gas smell.
There have been reports of gas ranges which have been installed with no leveling legs. (due to various reasons, like a new floor installed, but the counter tops stayed in the same place, so the range surface would be higher than the counter top if the legs were installed) In some cases, this results in an insufficient amount of combustion air for the oven. To test this, put the range up on a set of 3/4 inch or so blocks and try the oven again. Let me know how that went. Thanks.
Apr 29, 2009 | Kitchen Ranges
Gas stove stopped working
Hi . I would begin by pulling the stove out and making sure it is plugged in. If it is, unplug it and plug something else into the plug like a blow dryer to make sure you have power to that outlet. If there is no power, you have either blown a fuse or kicked a circuit breaker. Go to your electrical panel to replace the fuse or reset the circuit breaker. good luck.
Feb 01, 2009 | Kenmore Kitchen Ranges
Igniters pop about every 10-15 min
It appear that Bosch stoves are sensitive to the orientation of the hot and neutral. Mine was reversed at the outlet. I changed it to be correct and it fixed the problem
Sep 07, 2007 | Bosch HGS442UC Gas Kitchen Range
Jenn-Air JGS8850BDS Stainless steel Gas Kitchen Range Logo
117 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
