Question about Bose Wave Radio II
Change time on radio - Bose Wave Radio II
  • 942 Answers
To change time, here's how:
Reading the clock display
You can set the Wave radio to always show either the clock display (Figure 10) or the radio
display when the radio is on.
To change the display mode, press and hold Clock Set, and then press the AM/FM button.
Customizing the display
Function Control panel
To set the clock - Hold down the Clock
Set button and press Tuning up (4 ) or down
(3 ). The time display changes slowly at first,
then faster. Release the Tuning button to stop.
To set AM/PM (12 hour) or Military (24 hour) time - Press
the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between
AM/PM (12 HR) or military (24 HR) formats
To set the display to clock or radio mode - In the clock
mode, the display shows the time while the radio is on; In radio mode,
the display shows the selected radio station.
With the radio turned on, press and hold Clock Set and then press the
AM/FM button to switch between clock and radio modes.
To adjust the display brightness - In low light situations, the
display dims automatically.
To adjust the brightness level for the automatic dim setting:
• Hold down the Clock Set button while pressing Volume up to view
the 10 levels of increasing brightness.
• Hold down the Clock Set button while pressing Volume up or down
to select you preferred setting.
The selected setting is retained by the radio with the 9V battery as
backup in case of power loss.
Function
To turn on/off - Press once to turn on (to the last source played) or off. Or,
press AM/FM or any Presets button to turn the radio on.
for more info, click this link: highlighted in violet:
This is the bose manual for wave radio. Turn it on pages 17-19
Posted on Nov 08, 2010
I Home clock radio time zone change. The I-Home clock radio did not change from DST to EST on Saturday evening at 2 AM
If it needs a Radio Signal to change TIME , try 2 things..
1 switch clock off, wait 30 seconds, then switch on. See if that works !
2 Put Clock near a window, or even better outside, as sometime Clock Radio signal will not be strong enough in the house
Nov 06, 2017 | The Audio Players & Recorders
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
The time has changed here in Ohio, and we need to roll back an hour, have lost manual. How do I change time?
http://www.retrevo.com/support/Sony-ICF-C318-Clock-Radios-manual/id/2727ci362/t/2/
you can download the manual from here, chk n change ur time from it
njoy..
Nov 01, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
Time change
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
Change the time on the base radio
On the right lower of the radio there are 2 arrow buttons. one changes the hour and the other changes the minute.
Mar 11, 2009 | 2006 Chevrolet Colorado
How to change time
i have a 212 all you need to do is hold on the time button "Hour" or "Min" and click on change button, it sequentially increases set you desired time after it reaches 12:00 it would change automatically to AM/PM so dont worry about that now.
Nov 03, 2008 | Sony ICF-C212 Clock Radio
Daylight Savings Times Changed
We set the time zone to '7' , which is Hawaii time zone where there is no change for daylight savings. This came up because it changed automatically on this morning...and although we can change it back, then it won't change next week when it should. So we're hoping that by setting it to Hawaii it will be a regular clock, we will do the changing...but at least we won't be surprized as we were this AM.
lb
Mar 09, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight savings time - cannont change time
hold down either the + or the - depending on how you want to change the time. If you just hold the button down for 3 to 5 seconds the time will start to go up or down.
Nov 04, 2007 | Bose Wave Radio
Changing time on RCA CD clock radio
UNPLUG!!! Wait 15 seconds. Plug in again, CLOCK will flash 12am.
Press "set" button ONCE.
Press Double Back Arrows |<< to go backward from Midnight
or
Press Double Forward Arrows |>> to go forward from Midnight
(Either press-hold the Double Arrows for quick minute-scroll or repeat-press Double Arrow for a slower minute-by-minute change.)
Sep 20, 2007 | RCA Radio Alarm Clock
Bose Wave Radio II Logo
757 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
