My LCD TV is Tevion MD20099. It has a noise coming from the speakers. It is a high tone which remains constant against the volume control and only goes off when I set the volume level to '0' or activate 'Mute'. It comes in all inputs. Could u please help? Ravi.
    President:
  • 1,779 Answers
It is most likely your main control panel of which you will probably never fine with that generic set. Sorry....
Posted on Jun 16, 2008
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
High pitched noise coming from TV
could either be the speakers on the tv packing up and the only best way to fix this either take it into a shop to get repaired or just bin and get another one depends on how much it would cost to fix
May 18, 2012 | Memorex MT2206 TV
My Aiwa Colour TV, model No. TV-A2019, has developed audio problems. 1. The audio output from the speaker is high even when volume is set at level one. Audio output is constant for volume level 1 to...
You just come aroung the sound decoder section of your tv. Decoder problems may cause the fult you pointed out. Since all the controls are electronically controlled, and all are through sound decoder, which converts sound to stereo the problem must be there. Since sound comes from two channels are ok, there is no problem around sound output. Check for some soldering loose contact, wire socket loose cotanct also.
Oct 14, 2010 | Aiwa F2000 20" TV
Tone switch causing loud pop in speakers tripping protectiveRelay
The tone control on this one sounds like it is an active one and either using the low or high pass filter you would be boosting the higher or lower frequencies. Boosting the lower frequecies will be harder on the amplifier, in which case if you would like to use then you may need to connect speakers with a lower impedance or higher sensitivity.
Dec 12, 2009 | Sansui RZ-5300AV Receiver
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
Tevion 19 LCD TV Model Number 1961HDT
these come with 3 year warrenty ... ring their helpdes in uk 087 663 1540
May 02, 2008 | Televison & Video
100watt sub
There is a problem wwith teh power supply or the amp section. Does the noise remain constant or does it vary in volume? The sub should have a level control, does the noise vary with that control?
Dan
Mar 19, 2008 | Kenwood SW-38HT Subwoofer
A high pitched tone is constant when the TV is on
The problem could be that of coil that has become loose and is vibrarating cause your squeal . Or it may be a transformer in the power supply that is also vibrating . These can only be replaced to get rid of your problem and you have to isolate which one is causing the noise . Good luck
Mar 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Plasma sound problems
Sounds like the TV volume is set too high, with little or no audio input.
If the sound is coming from the speakers and you are using an external input such as a cable box you may need to turn up the volume output from the box, and turn the TV volume down.
Mar 05, 2008 | Philips 50PFP5332D 50 in. Plasma...
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
