Question about Pioneer DEH-1600 CD Player
My "Power Wire" (Red)
  • 656 Answers
The red wire will be connected to fuse in the motherboard or on the back of the cabin remove the cabin and solder the wire to the first line of the fuse in some mother board it will be marked AC There will be two holes in the motherboard in some connectors are use after the fuse you will see dies then a capacitor
Posted on Nov 08, 2010
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
Need pinouts diagram for Pioneer DEH-1600 CD Player
ok my friend has a 1999 ford f150 and we took the radio out to put in a poineer deh-1600 and we bought the connectors but one of the connectors doesn't fit and there was for wires were free when i got done the wires was a solid black with a white stripe, a solid orange with a white stripe, and a solid blue and a solid orange cable left tell me what do those wires goes to
Jan 16, 2010 | Pioneer DEH-1600 CD Player
What wires go where on a pioneer deh 1600
Need what year, make, and model your vehicle is, but the yellow is positive constant
red is positive Acc.
black is ground
orange is illuminator
blue is if you have power antenna
white and grey are front speakers
green and purple are back.
email me with your info so I can tell you where they go in your vehicle.
xxsodasipperxx@yahoo.com
Nov 27, 2009 | Pioneer DEH-1600 CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Some one removed my radio just cut wires, how do I put it all back together
okay the two most basic things you need to know is that the red wire is a live wire from your battery clip whatever residual wire is hanging from it and don't let it touch anything metallic the conclusion would be bad. And also that the black wire is ground
As far as speakers go you will have to try them one by one to figure the channels LR,RR,FR,FL good luck
Mar 26, 2009 | Pioneer DEH-1600 CD Player
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
Wire diagram
www.pioneerusa.com
red-12 volt ignition
yellow -12 volt regardless of ignition switch position
white-left front speaker +
white /black stripe speaker -
gray- right front spe +
gray/stripe right spe -
green-left rear spe +
green/stripe left rear spe -
purple- right rear +
purple/stripe right rear -
if this helps you please give a good rating- thank you
Aug 09, 2008 | Pioneer DEH-1600 CD Player
Pioneer deh 1600 has no power
just run both red and yellow to 12v ...
well put the red on a constant 12v source then
yellow you need to put on a 12v source that comes on and off with key ..
yellow wire can go to the fuse box and take a non-using fuse out and put wire in it and should have power .. ..
i would recommend to locate the cars original wires tho ..
i am no pro iam just an average joe but i kno from installing stereos in many many cars .. ive done hack jobs to comp ..
hope this may help you
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Car stereo
Most current Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 05, 2008 | Pioneer DEH-1600 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Pioneer DEH-1600 CD Player Logo
32 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
