Question about GE WHRE5260E Top Load Washer
Water leak My washer is leaking in the front. I took the bottom off and found a 1/2 in diameter black hose not hooked to anything with water coming out. I can't find where it hooks to anything? Any ideas? It's not the main drain hose.
  • 481 Answers
It sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Posted on Jun 27, 2008
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
Whirlpool duet leaking water from bottom of washer-after I noticed the water on the floor from the washer leaking from underneath, I took the clothes out and tried to run the machine without clothes in it....
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 01, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a leak coming from the bottom of my Kenmore 24722. All hoses and connections are sealed properly and are not leaking. The leak looks like it is coming from the gearcase towards the front bottom...
May 20, 2010 | Kenmore 24722 Top Load Washer
Water leaks on passenger floor in my 97 honda civic
I have a 1997 Toyota Camry. Water was collecting on the front PASSENGER floor after a rain. I opened my sunroof and found the front drainage holes (about 1/8" diameter) in the corners of the track sunroof track. They looked clear. I poured a bottle of water in track and watched the result. Sure enough, water started dripping from the right ride of the glove box on to the floor. I started tearing out the interior panels to trace the leak. What I found is that if I poured the bottle of water REALLY slow into the sunroof hole = no leaks. But if I pour it too fast the small 1/8" hole cannot keep up and the track overflows! THAT is where the leak comes from in my car! If water overflows the track, then it makes its way down the column trim, around the glove box and on to the floor.
So I need to help the 1/8" sunroof hole drain faster. I took some 18AWG TFFN electrical wire and jammed it into the hole to help clean it out. I then removed the black plastic mud flap behind my front tire and blew out all of the leaves and rotted debris that where behind that flap. It was packed with junk! I poured more into the 1/8" hole and it seemed to drain quicker.
I hope this information helps others.
Apr 28, 2010 | 1997 Honda Civic
My 1 yr old Cuisinart DCC-1100 coffeemaker leaked all the water out. Took off bottom and found that 1 hose is split. Was told that warranty is void because bottome was removed. Can I get a hose anywhere?...
You might try the Home Depot, Lowe's, or ACE Hardware stores. Just mesure the internal and outside diameter of the hose and its legth. Put that hose in the boiling water. That water cleans up the hose and warms it for easy installation. Please let us know if you still have the problem.
Feb 25, 2010 | Cuisinart Coffee Makers & Espresso...
My washer is leaking from the bottom. I took the bottom panel off and found a black hose that is not attached to anything. When the washer is filling up the water is leaking out of this hose and all over...
if the hose is comming off the bottom of the tub, it will usually connect to the pump
if its the one afte the pump it may connect to the inside back wall, where your drain hose is
Oct 06, 2009 | GE Washing Machines
Tub leaking
Mar 03, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water Leaks from beneath my washing machine
Our WM2077CW just started the water leaking from underneath. We unplugged the electrical cord and disconnected the hoses (water, drain). We then removed the inspection plate from the back and checked for wet hoses. The big black hose on the bottom was a little wet. On careful examination we found a small hole that looked like a material fatigue failure at the point where the accordion part of the hose met with the solid part of the hose near the main drum connection. I suspect this is may occur in other LG washers of the same design. Unless your floor is perfectly level it's hard to tell whether coming from the left or right side really indicates where underneath the water is coming from.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
GE WHRE5260E Top Load Washer Logo
124 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
