My keyboard is not working properly, when my pc power on then hang my keyboard and alternately glow all keyboard's LED.
  • 70 Answers
Hello, friends there is on problem in your keyboard in your pc there is virus which hang your keyboard please reboot your window drive then it will work. Best of luck
Posted on Nov 08, 2010
Phone is not booting (no display only LED glow)
Why don't U hard reset the phone. It may delete everything on it. But it will bring it back to the state when U bought it new. Good luck.
Here is how.
http://www.youtube.com/watch?v=yTcfCJmWU_U&sns=em
Feb 27, 2014 | Sony Ericsson W380i Cellular Phone
Most of the time while I'm switching on it, power led does glow, HDD Led glows once and also can here the spinning sound of Processor fan but there is no display and after few seconds it will restart. if...
two solutions:
1- use a cooling hardware. maybe your laptop hangs because of high Temprature.
2- VGA of your laptop almost destroyed !!(sorry damaged).
so you can only take your laptop to a guarantee center.
Jan 10, 2011 | Compaq Presario F572US Notebook PC
3 beep sound
If a PC suddenly fails to boot properly, you should perform a hard reset as the first action. Performing the hard reset will correct many problems. If the computer still does not start properly, select your symptom from the list below to guide you to the recommended corrective actions.
  1. Disconnect all peripheral devices and remove all USB devices and SD media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain all residual power and restore default startup settings.
  3. Reconnect the AC power adapter (but do not insert the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a fan or other moving parts turning.
  4. If the computer does not start, the LED lights do not glow, and the display is black, you can perform one or more of the following actions to resolve the no power issue.
    • Verify the computer is receiving power from the AC adapter . Verify that the AC adapter is not damaged and is connected correctly to a working wall outlet plug. Verify AC power is connected to the system board by examining the AC adapter, wiring, and pin connection for damage. The keyboard LEDs will glow when AC power is connected to the system board. Damaged components, like the AC adapter or the pin in the power connector, may require an HP-certified repair.
    • Use a different AC power adapter . If you have access to a different AC adapter or power pack that is designed for the computer, connect it to the notebook and try to start the computer. If you own or have access to more than one notebook, verify that you are using the adapter which belongs to the notebook. CAUTION: Using a power adapter that does not meet the power requirements or has the wrong type of connector may damage the computer. On newer notebook models, connecting the wrong adapter to the notebook may cause the power LED lights to blink but not power the computer.
    • Remove the battery and boot on AC power only . A discharged or defective battery may prevent the AC adapter from supplying enough power to start the computer. To verify that power from the AC adapter is available for PC; remove the battery, connect AC power adapter, and press power button. If available, try using a different AC adapter, that is rated for the PC, and repeat this test.
    • Remove the AC adapter and boot on battery power only . A defective AC adapter may not charge the battery and prevent the computer from booting on battery power only. To verify battery power available for the PC; connect AC power adapter, allow battery to charge for 30 minutes or more, disconnect the power adapter and press power button. If available, try using a fully charged battery, of the same type, from another computer and repeat this test.
      • If LEDS do not glow and the fan or hard drive do not spin, battery may need to be replaced.
      • If tests of both the battery and the AC adapter fail, there may be a problem with system board requiring service by HP.
      • If LEDs glow and PC boots, the AC adapter may need to be replaced.
      • If LEDs glow, but PC does not boot go to LEDs glow, fan is heard, but display is black or blank section.
Nov 21, 2010 | HP Compaq d530c PC Desktop
Logitech Laser Mouse not working properly
Nothing to worry Just your LED has given way due to long usage. It seems you never switch off your UPS or power supply properly because you can monitor for yourself even after shutting down your red laser on the mouse will keep on glowing until you switch off the power supply to CPU. You can use your mouse without that LED also.
Sep 07, 2009 | Logitech Cordless Desktop MX3200 Laser...
None of my F-keys seems to be working... I run in Windows 7. All the other keys are working fine.
It may happen that ur keyboard drivers are available and u have not properly installed so according to me first uninstall and then reinstall it.It may work
Aug 03, 2009 | Logitech Cordless Desktop Ex100
My toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
Aug 02, 2009 | Toshiba Satellite A60 Notebook
Thinkcentre M55 8806 power on off problem
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Dec 26, 2008 | Computers & Internet
Keyboard wont work on my dell desktop
check out for the key board pins wheather its good,and its connected properly,check out the green led in the keyboard wheather is glowing or not ii the light is not glowing then its not getting the power supply remove the pin and connect it again ...if u still face the prob change the keyboard
Apr 04, 2008 | Logitech Cordless Desktop MX3200 Laser...
No power!!!
Dear javier4017,
> First ensure that any beep is coming or not
> check numlock LED status glowing or not.
> If numlock LED glowing it means cpu working fine
only problems with monitor
>If numlock LED not glowing its mean problems with cpu
> if problems with CPU Find check RAM may have dusting problems.
Dec 07, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
