Question about JVC Video Cameras
It does not show picture or play mode on screen. just has a blue screen
  • 3,083 Answers
The most likely cause is that the battery has aged- this problem was reported by other people on the net. Try hooking up an adapter to the camera to see if it fixes it. Another person on the net reported that a battery would cost him $120, so, depending on the type and age, it may not be worth the cost of repair to have it fixed. Google the model + battery and you'll get some choices on the net. Then you'll have to make the choice of repair or replace with a newer one.
If the problem isn't the battery, it could be a loose ribbon connector or other fault within the camera, and would need servicing. Get an estimate before having it repaired, as it can be costly.
Good luck, and hope this helps.
Posted on Nov 08, 2010
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
A thick blue horizontal line appeared in my LCD screen and won't go away. I can still take pictures and they print out fine, but how can I get rid of the blue line?
This is probably a problem with your LCD monitor or the connections to it. Does the blue line show in all situations such as record, playback, and menu mode?
Test your monitor by plugging into your camera the TV cord that came with your camera. Connect to a TV and use it as a monitor when your camera is on. be sure to switch to the TV to channel three or video to get a picture. Check the different screen modes: record, play, and menu. If the blue line does not appear on the TV then there is damage to your monitor or its connections. My guess is you won't see the blue line on your TV since you get good prints. If you are on warranty, get it fixed. Otherwise, you have a choice between paying for a repair or living with it. Good luck.
Nov 27, 2009 | Olympus Cameras
My camcorder screen stays blue when its in play mode.
Try to run a cleaning tape, it should solve your problem.
Aug 15, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
CAMCORDER PROBLEM
picture both in camcorder and picture only mode is mauve.
Jul 20, 2008 | JVC Video Cameras
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
The camara won't show a picture on the lcd screen
Your lens is Damage. Prevent nextime from sunlight , it damage your lens if not in use.
Dec 24, 2007 | Canon PowerShot A75 Digital Camera
Tapes wont play in palmcorder vcr mode
just clean the video head and you will get the image.
Oct 31, 2006 | Panasonic Palmcorder PV-DV53 Mini DV...
The vcr will sounds like its working but no image or sound on screen
Hello brother, It looks that is no problem in vcr mode I think you just need to play a head cleaning cassette. I hope it should solve your problem All the best to you Uday
Sep 02, 2006 | Sony Handycam DCR-TRV230 Digital Camcorder
LCD screen goes plain grey
i think it's the case of damaged flexible cable to the lcd screen from the camera. a replacement will do the job
Jun 27, 2006 | JVC GR-DVM5 Mini DV Digital Camcorder
Video Cameras Logo
26 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
