Question about Maax Acrylic Base for Shower - 102623
I need to remove the Maax shower base and can not figure out how to remove the wedge retainer. do i need to actually cut the shower base to get the pipe detached to remove the shower base?
    Novelist:
  • 157 Answers
Hello, You shouldn't have to resort to that extreme. The drain unit that the retainer sits in is the part securing the base down, have a look at the diagram in this link: http://www.maax.com/Upload/docs/premium/technical/en/000_10014442_0904-2_E.pdf
The drain assembly should unthread and release the base. But sometimes they tend to work as designed.
The retainer is a compression fit (or should be... do you know the installer? they may have deviated from the described installation). Assuming a proper install, use a flat-head screwdriver and a utility knife to seperate the inside portion of the rubber seal of the retainer, from the plastic ring. The ring should now be able to be pried out, and the drain portion unthreaded.
If this helped, please rate a four-thumbs up. Thank You.
Posted on Mar 26, 2011
Maax shower base installation
I would just cut enough to install the pan by the way does the drain line hook to this pan? that will give it support as wwell
Apr 30, 2014 | Plumbing
Chipped shower base
Supply stores, lowes, home depot sell two part epoxy for fixing this. Although epoxy says for porcelain it can be used on other types of materials.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Mar 30, 2014 | Maax Acrylic Base for Shower - 102623
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
I have a Maax Tigress shower. This will be 3rd time I've taken shower door frame off base to recaulk. I have leaks where frame meets base. I don't think base is stiff enough, because I can feel it flex...
If the GE Silicone was used first then this may be the cause. For some reason the GE formulation does not adhere very well to new plastic/acrylic, however it does very well on most other surfaces. The mono brand is better for plastics/acrylic. If all of the GE silicone was not removed before the mono was applied then the mono formulation would not stick very well to the GE silicone that was not entirely removed. Unfortunately there is no easy way to do this other than with a plastic scraper tool and lots of elbow grease. Rubbing alchohol can be used to soften the silicone slightly and will not damage the acrylic, aluminum or glass. If the mono was applied first then the flexing will be the problem. The only solution to a flexing problem is to remove the shower unit and reinstall the unit in either a morter or sand base to provide more support for the shower unit. If you use a morter base ensure there is a vapour barrier installed between the morter and the shower unit as the chemicals/minerals in the morter will degrade the shower base over time. The downside to morter is that it will not flex and may cause cracking over time if and when the house shifts. A sand base will shift with the house.
Aug 21, 2010 | Maax Home
Does the styrofoam liner stay in the base of the round shower base?
If it fits flush under unit, yes, leave it there. It helps as a structural support for the floor.
It it stick out at all take it out as it is just packing material.
Hope that helps.
Feb 09, 2010 | Maax Breeze: Two Piece Round Shower Module...
Maax Acrylic Base for Shower - 102623 Logo
2,332 people viewed this question
Top Maax Plumbing Experts
Donni Steen
Steve
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
