Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I get a small puddle of water in front of frig, about once every 2 or 3 weeks
    Problem Solver:
  • 9 Answers
THe defrost siphon tube in freezer is partly blocked. Turn off fridge, remove cover of condenser and check the drain tube for blockage.
Posted on Nov 08, 2010
Model #970658324 leaking water from the freezer to top shelf of frig once a week probably with defrost cycle. Help!
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Jun 04, 2012 | Kenmore Refrigerators
LEAKING FRIG SOMETIMES SMALL PUDDLE OF WATER IN FRONT OF REFRIG
drain hole is plugged, usually frozen with ice, consult owners manual on how to defrost drain hole. Hot water usually does the trick.
Jun 09, 2010 | Amana ABB1927DE Bottom Freezer...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
About 1/4 inch of ice forming in bottom of freezer about every 3 weeks. small puddles of water form under the front of frig when this freezes
That is a typical defrost drain blockage symptom unless the icemaker is over flowing, I will return with a link and more information. Sea Breeze
Jan 18, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frig. and Freezer not cooling. Clicking sounds heard every 2 mins
sure sounds as if it is def a compressor overheating, now that the compressoe will be cooled it should work , but your right damage may be already done, the good news if any is that you should be covered under 5yr manufactures warr for compressor
Dec 22, 2008 | Maytag MTF2155GRW Top Freezer Refrigerator
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Leaking frig.
Freezer bottom, take out the drawer, There is a gutter in the back elevated with a hole towards left. Somewhere it said stick a chinese chopstick or smt that wouldn't damage insides but that did not work.
I did that for a second time after a week today (it leaked again) and immediately after I put 1 tea-spoon of baking soda and two cups of hot water through that hole, as per ge service site, pdf files 39-6296 p11? and 39-6401, which are users manuals. search with model no. like csh24gr ending with t or x both older models come up anyway.
Drawers brake esy, becareful. No pan back or front undersides for drain or evaporation. There is some schematics to how they engineerd the evaporation.hotptci
Nov 22, 2008 | Refrigerators
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
130 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
