Question about Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
HOW TO REPLACE DRAIN PUMP IN WF218 - Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
PUMP CAN BE ACCESSED FROM THE BACK OF THE MACHINE
Posted on Nov 08, 2010
2 Suggested Answers
  • 6277 Answers
SOURCE: samsung wf218 washer will not
Try all of this first!
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 01, 2011
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    How to fix drain hose on LG WM2487H M
    The following are a number of things to check for the OE (drain error) indication.
    If the washer does not drain then the drain pump may be clogged, damaged, or defective.
    Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
    First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
    Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
    It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
    Mar 08, 2016 | LG Washing Machines
    I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
    Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
    Jun 24, 2015 | Samsung Washing Machines
    Samsung wf218 washer will not drain. already cleaned drain and placed in spin cycle to see if it will drain. Did not work. how do you get pump out. is it thru front panel or back. do you have a...
    John C
    Jul 01, 2011 | Samsung WF218ANW 4.0 cu. ft. High...
    Cabro WTW6200SW2 Top Washer. Water drains on the floor instead of through the drain pipe.
    This one sounds like the drain pump is damaged or the drain hose is damaged or detached causing water to drain on the floor instead of through the drain hose. Disconnect power then tape the washer lid closed and lay the machine on its front on a cushioned surface to access the drain pump and the drain hose connections at the bottom of the tub. Reattach the drain hose if detached or replace it if damaged and cannot be reattached to the drain pump. Replace the drain pump if damaged and leaking water on the floor.
    Mar 05, 2011 | Washing Machines
    My Hotpoint wdm73 won't drain. how do I fix it?
    1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
    2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
    Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
    Washer wont drain displays OE. Pump makes a vibrating sound lie it is plugged already checked filter cleaned it removed hose how do you replace the pump?
    Hello & Welcome to FixYa
    OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. If the issue returns then yes you should replace the pump, please check this repair manual on how to replace the pump. Please get back to me if you have any other questions.
    Kevin
    Dec 12, 2010 | LG WM2688HWM TROMM SteamWasher
    Drain pump won't pump
    Check on voltage to the drain pump and if present during the rinse and after wash cycle but failing to drain out, then the drain pump is faulty.
    Remove the drain pump and check coils , if open then replace pump.
    Other wise clean the pump and reset.
    Sep 01, 2010 | Fisher and Paykel Washing Machines
    Samsung model WF218...not draining
    Just follow the few steps here as follows. First switch off and unplug the mains. Now you look for the screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water in the tub bottom. Examine your pump also, clean out the impeller. Carefully refit all. For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment. Check the exit hose of the washer for blocks.
    The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there is a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.
    Now your machine will be in good maintained condition. Hope this would have helped you.
    Jul 22, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
    MY SON'S DISHWASHER WON't drain
    Hello there:
    Please try these things below my post and click on the links that are available for you ok
    I hope that tthis is very helpful for you
    best regards michael
    Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
    dishwasher_drain-hose.jpg Drain Hose
    It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
    dishwasher_pump-repair-kit.jpg Pump Assembly
    The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
    dishwasher_belt.jpg Belt
    It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
    dishwasher_timer.jpg Timer
    A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
    dishwasher_motor.jpg Motor
    The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
    dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
    In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
    Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
    Samsung WF218ANW 4.0 cu. ft. High Efficiency Front Load Washer Logo
    1,078 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
