Question about Water Heaters
Can propane liquify inside the tank during temperature changes and therefore have proplems dispensing
  • 760 Answers
Propane is liquid in your tank. The vapor pressure will depend on the temperature as you can see by the following chart. For an example at 0F the vapor pressure in the tank would be 24.5 psig. and at 90F it would be 150psig. This is why you draw vapor from the top of the tank and then go immediately go through a high pressure regulator. Then usually at the appliance there is also a regulator (sometimes incorporated in the safety valve) You are burning propane as a vapor not a liquid. Remember for safety that propane vapor is heavier than air and sinks to the floor, so one must be careful for proper ventilation.
Temperature vs Vapor Pressure
(oF) (oC) (psig) (bar)
-44 1) -42.2 0 0
-30 -34.4 6.8 0.5
-20 -28.9 11.5 0.8
-10 -23.3 17.5 1.2
0 - 17.8 24.5 1.7
10 -12.2 34 2.3
20 -6.7 42 2.9
30 -1.1 53 3.7
40 4.4 65 4.5
50 10.0 78 5.4
60 15.6 93 6.4
70 21.1 110 7.6
80 26.7 128 8.8
90 32.2 150 10.3
100 37.8 177 12.2
110 43.3 204 14.1
Posted on Nov 08, 2010
I'm temporarily staying in our RV while our house is re-furbished. The water heater is only working intermittently. Can anybody help me?
RV water heaters are mounted against an outside wall. Go outside and look for a removable cover that has a mesh vent installed.
Open this cover and the water heater should be inside.
If the water heater is propane your propane tank may be low of fuel. Also very cold weather may not let the propane produce adequate vapor to fuel the water heater. A low level of propane can make this problem worse.
If the water heater is electric, you may have too large a wattage draw from other appliances, when the water heater is trying to heat. Turn off items such as hair blowers, AC, and Microwave when the water heater is on. If a generator is providing the electricity it may not have enough output. If shore power is providing the electricity you need at least 30 AMPs.
Apr 20, 2016 | Water Water Heaters
Superflue. Why doesn't it stay lit?
If this is in a RV there is a propane monitoring valve. It will close and cut of the propane if it is not being used for a period of time or if there is a leak. The valve is mounted between the propane tank and the first appliance, usually inside the RV.
Mar 09, 2016 | Water Water Heaters
Zwc28 1mf2k31 poor flame
Check in coming water flow . Check water flow at heater maybe blocked inside reduced flow .
Aug 01, 2017 | Water Heaters
Last year we had all the siding on our tv, trailer, replaced due to hail damage. When we finally got our trailer back from the rv repair shop we have had nothing but problems with our Atwood hot water tank...
Immediate danger!
You have a gas leak.
Propane is heavier than air and will settle on the floor.
The floor can be covered and ignite and you will not smell it while standing or sitting or laying in bed.
Absolutely open the door and leave trailer. Turn off the gas to the heater if the shut-off is outside.
Possibly you have a bad gas control valve. This should be repaired professionally.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 08, 2012 | Water Heaters
Water leaking from bottom of quick and hot dispenser only 18 mos old
I had the same problem. There is a 2 piece metal tank inside. The top and bottom of the tank are connected with screws & nuts, and there is a rubber o-ring between the two pieces. The grove for this o-ring is very shallow and it doesn't fit tightly, increasing the probability of misalignment during the assembly process. I was unable to fix the leak, IMHO the grove is too shallow and the o-ring is not thick enough. I decided it was poorly designed & trashed the unit.
Aug 26, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
Dsi flt light keeps going on and the black water light says full when we just emptied it.
DSi light coming on is to alert you that the water heater didn't light on propane for one reason or another. Sometimes people just forgot to turn propane on or are out of propane. What happens when you shut it off and turn it back on? (listening and watching from outside with cover open) DO you see or hear sparking?
As far as black water showing full when just emptied, it is most likely a piece of toilet paper inside the tank that is hanging up from top probe on inside of tank, and touching lower probe, thus giving a full reading. This is very common, at all levels. You can buy a rinse wand and rinse inside of tank through toilet to try and wash it off, or live with it for now, and add lots of water or cleaner deodorizer to tank , or buy probe cleaner, or even the old standby, some laundry soap added to tank , then fill tank close to full with water and rock trailer to swish it around, then drain it. Most times, waiting until next dump, and adding lots of water beforehand, will fix it.
Jul 11, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Turn on water the electronic ignition not coming on
The tankless water heaters require larger gas supply lines because of the on-demand consumption. While I don't know your units rating, most Propane Tankless Waterheaters require 2" supply lines. Moreover, pressure is directly related to temperature which sounds like your problem entirely; consider the run of the gas pipe from the tank and the ambient temperature. Now you see why plumbing is a hard profession to fake... =)
Nov 19, 2008 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Water Heaters Logo
300 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
