Question about Navman iCN 520 GPS Receiver
MMCX adaptor broken off,
Small part of MMCX adaptor still in Navman ext antenna outlet,How do i get it out without damage to unit.
Zoom b2 powers up with batteries, but not the power supply
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: -V). Resolder.
  • Damaged (broken) in D2 or R76. Replace
Jul 04, 2014 | Zoom B2 Bass Multi Effects Pedal
Navman Tracker 5500
I am having same trouble. I contacted Navman NSW and went through all the settings without result. It was suggested that the problem could be the external antenna, if not a fault in the machine. I have seen an after market antenna for about $19 so I might try that. It does seem as though the antenna is not talking to the Tracker.
Dec 10, 2012 | Navman Tracker 5500i GPS Receiver
What fitting is the external antenna is it mmxc?
I hope everybody visiting this webpage will find this answer useful.
First of all, ignore the antenna connector recommended within the RAC Sat Nav 200 manual, it's wrong.
What you need is the :
GPS Antenna 1M Length MMCX with a
180 degrees straight connector.
Make sure it's a MMCX straight connector.
Plug in the antenna and within half a minute of typing your postcode destination into the Sat Nav the reception will have been picked up.
Hope this saves everybody a lot of hassle.
David Coggon - Author of Children's Book ` Jack's Crayons '
http://www.ahstockwell.co.uk
Aug 04, 2009 | SNK RAC SAT NAV 200 GPS Receiver
Tom tom one cant find signal.
First checkpoint is the internal antenna - you can check this by getting hold of an external one (they're about AUS$20 off the net, make sure its got a MMCX connector). If that works, the internal antenna is detached/failed. This may be beyond a home remedy and require HP repair (or just settle for using the external antenna).
Feb 21, 2009 | HP iPAQ rx5915
External Antenna Conection
Ref ICN330. The external antenna connection is on the top side of the flip up Antenna on the unit itself. There is a small rubber plug covering this, adjacent to the Navman logo.. Ricmac
Feb 12, 2009 | Navman iCN 330 GPS Receiver
Nav-cam 7500, gps signal poor and takes up to 30 mins to respond.
Overcome the problem, bought an external arial (magnetic). Bought it on E Bay for a couple of pounds. You have to put it on roof when travelling it works great, socket is mmcx.
Charlie
Dec 22, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Antenna input
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Aug 26, 2008 | TruTech PLV16320 Television
BROKEN LCD SCREEN
I have seen this with cameras, and pocket TV sets.
It is best to send the unit back for factory service. Ask for an estimate before servicing.
The parts in your GPS are not generic parts. You can buy the screen from the manufacture and find that the circuit board under it is also broken or damaged.
You may also find that the cost of the screen replacement may approach the cost of a new unit. I have seen this on many small devices. In some models the screen module comes as part of a complete matched assembly.
Jerry G.
Jul 01, 2008 | Navman NavPix N60i GPS Receiver
ICN 500
tall buildings in the cbd reflect satalite signals causing incorect fixes. an ext antenna helps a little bit.
Mar 13, 2008 | Navman iCN 520 GPS Receiver
GPS Antenna
hi
the 8400 does list an antenna accessory but no socket type
there is also a speaker/headphone out socket
are u sure you are not confused
mmcx and larger mcx are common types
http://en.wikipedia.org/wiki/MCX_connector
GSN 8400 manual here
http://www.uniden.com.au/RESOURCES_MAIN/pdfs/GNS8400_OM_ForWeb.pdf
D
Nov 04, 2007 | GPSRD Radar Detector
Navman iCN 520 GPS Receiver Logo
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
