Question about Sanyo DP50747 50 in. Plasma TV
I have my wii hooked up to the tv, but i cant hook my dvd player up because there isnt a second yellow plug.
  • Sanyo Master
  • 8,457 Answers
Ur tv and DVD player have a S-Video connections ports holes for this wire right?Tries websites like Amazon.com,Ebay.com to buy this S-Video wire to used to do the connections for the tv and the DVD player together by this S-Video wire in tv S-Video and DVD player S-Video connections ports holes for this wire.Use the AV cable RED,WHITE same connections like ur Wii connections to get the Audio.
Posted on Nov 08, 2010
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
Old TV
I can assume the input for your tv has only a coax input to it. Meaning a threaded connector on the back. If so, first connect the Wii to the input of the dvd player, second, from the output of the dvd player, this is where your solution is needed. run a coax cable from the tv to the DVD player and at the dvd player you will need an adapter from your local Radio Shack or electronics store. It should be a female coax to RCA adapter (male Red White and Yellow).Red and white for audio and yellow for video. Post a pic of the back of the tv if this doesnt solve it for you. Good luck, fingers crossed.
Sep 07, 2012 | GE 25GT240 25" TV
We are trying to hook up our wii console how do you get it to work. TV says invaild scan freq.
You have to hook it up to a standard Yellow/Red/White RCA jack. If it doesn't work on one, try another. Make sure you're on the proper input you hooked it up to on the T.V. If this doesn't work, try hooking it up to a different T.V. to rule out the Wii as the problem. Try hooking up a DVD player to the same RCA jack as the Wii was on the Hitachi. After all of these troubleshooting methods, you should be able to get your Wii properly hooked up.
Jun 24, 2011 | Hitachi UltraVision UT47V702 47 in. LCD TV
I have a mitsubsishi 65 inch DLP hdtv and i need to hook my dvd player and wii game to this tv and i cant figure this out please help>>>>>me :_)
Your TV should have atleast two slots allocated for game systems or DVD players. If not, then you can always use an HDMI cord for the DVD player and use the red, white and yellow connecters for the Wii.
Dec 25, 2010 | Televison & Video
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
I cant figure out how to run it through my dvd player
You should not be able to, the Wii has a mini disc player and is not compatible with any DVD player. The DVD player should have two plugs on it, one to the wall input and one with yellow and red input jacks if you don't have a AV in-put out-put connection on your TV then you need a adapter for to TV for the DVD player.
May 19, 2009 | Nintendo Wii Console
How do you hook up a wii to this thing?
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
Sanyo DP50747 50 in. Plasma TV Logo
245 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
